Old 09-07-2013, 01:16 AM   #926
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project "Just an Old Truck"
Originally Posted by jmedero View Post
Who would ever want one of those ugly Blazers. There is no possible way to make them look cool.
I always wondered what happened to this blazer?
It was one of my favorite "custom" 2wd blazers.
Sorry for the hijack and "gratuitous blazer picture".
Keith
Convert to disc brakes.
Old 09-07-2013, 02:03 AM   #927
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Shoot Keith... You can always throw a sweet Blazer pic my way! Very cool!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 09-07-2013, 11:07 PM   #928
C10_ustacould
Took the truck to a show today... A couple of hundred cars and mine was the only 67-72 but still no hardware! I don't go for the hardware I go to talk cars and trucks with other gear heads, and we did plenty of that today. All those cars and I only took pics of one...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-07-2013, 11:08 PM   #929
C10_ustacould
A few more from when the sun was out...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-07-2013, 11:10 PM   #930
C10_ustacould
After the show we cruised up to the local Hooters for a Show n Shine and some wings. I guess the Hooters gals liked the truck, they left a signed t-shirt for us!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-08-2013, 02:56 AM   #931
Rusbuilt
Rusbuilt's Avatar
Nice pics sir!! The truck looks awesome!
Rusbuilt is offline   Reply With Quote
Old 09-08-2013, 03:44 AM   #932
65 wonton
This is a great thread. I have enjoyed the read tremendously.
Question, though. What motor mounts and perches did you use. It kinda looks like you might have used the 73-87 stock perches & mounts with adapter plates. If not, then which?
Dave.
65 wonton is offline   Reply With Quote
Old 09-08-2013, 09:13 AM   #933
lolife99
lolife99's Avatar
x2
Keith
Old 09-08-2013, 10:41 AM   #934
RRC
RRC's Avatar
x2
X 3
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712
Instagram: http://instagram.com/rockylakekustoms
Rocky Lake Kustoms
Russ
RRC is offline   Reply With Quote
Old 09-08-2013, 11:03 AM   #935
C10_ustacould
x2
Originally Posted by RRC View Post
X 3
Thanks guys I appreciate it!
Dave.
Dave - I used ECE conversion mounts. I believe the lowers (frame stands) are 73-87 and ECE fabricates the upper mount. They set the engine farther forward than most other mounts, but I have had zero issues with clearance around the exhaust or accessories.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-08-2013, 07:28 PM   #936
C10_ustacould
Updated interior pic... No radio and I finally found an NOS lighter assembly to fill that hole.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-08-2013, 07:35 PM   #937
68basket
i am starting to mock up my vintage air install along with the wiring and ecu for the 5.3. how did you find room for it all in the dash? mine seems packed full.
68basket is offline   Reply With Quote
Old 09-08-2013, 07:59 PM   #938
C10_ustacould
I built a plate that is held in place by the radio/speaker screw up top and the heater support bracket screw on the bottom. And then I jammed all the wiring up in there as best I could. It will really depend on which harness you have.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-08-2013, 08:06 PM   #939
TruckFarmer
Turned out AWESOME. Love the look with that patina. Excellent job, sir.
TruckFarmer is offline   Reply With Quote
Old 09-08-2013, 08:36 PM   #940
1stchevy
1stchevy's Avatar
Truck looks great! Nailed the stance too.
1stchevy is offline   Reply With Quote
Old 09-08-2013, 09:20 PM   #941
68basket
everything i see you do is top notch!
is this mounted where the radio would go? no room left for a radio?
I have the PSI harness and really want to keep the ecm in the cab but may end up with it out in the engine bay due to space.
Old 09-08-2013, 10:14 PM   #942
C10_ustacould
Thanks guys!
I don't know about top notch, but it is a functional. There isn't much room under there and there are a couple of things that still need to be mounted... I'm the king of the zip tie! The bracket fits straight up and down flat against the firewall. It's sort of a z so that I could pick up the screw that goes into the cowl for the speaker/radio mount. The problem with the radio is after you get the bracket in there you have to tighten that screw and it is easier without the radio installed. Also my fuse/relay panel is living in that space right now, so I bought a radio delete panel and left the radio out. I have been kicking around the idea of mounting the ecm behind the seat. Porterbuilt has a set of panels that close out the space behind the seat and would be a great mount for the ECM and fuse/relay center. The downside is having to order another PSI harness that is about 2 feet longer. We'll have to see what happens with that.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-08-2013, 10:15 PM   #943
65 wonton
Thanks.
Dave.
Old 09-09-2013, 08:39 AM   #944
Bennett68C10
Bennett68C10's Avatar
I agree, truck looks great
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 09-09-2013, 08:55 AM   #945
cericd
cericd's Avatar
Hey Buck. Diggin' all the new pics!
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 09-09-2013, 09:21 AM   #946
builtbyKane
builtbyKane's Avatar
That's one sharp looking cruiser.
builtbyKane is offline   Reply With Quote
Old 09-09-2013, 09:25 AM   #947
shearjs
shearjs's Avatar
When you installed your Classic Instruments gauges, did you have to do anything special to get your tach working properly? I installed mine this past weekend, but haven't been able to get it going right just yet. I tried the switches on the back for 8 cylinder and also 4 cylinder to no avail. Truck looks great Buck. Can't wait to see the PB stuff on there.
shearjs is offline   Reply With Quote
Old 09-09-2013, 06:16 PM   #948
C10_ustacould
Thanks Keith!
Thanks Chris, What's up with your project?
Thanks bro!
I just set it for 4 cyl pulse for the LS and it has worked perfectly. Make sure you have good grounds and that the speedo has it's own separate ground if it's electronic.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-14-2013, 08:38 PM   #949
Xeen
Xeen's Avatar
The truck looks great Buck.
It's too bad there wasn't a goodlookin' girl included with that T-Shirt, but I guess a signed shirt will have to do.
I saw you taking a peek at my build, thanks for stopping by.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-14-2013, 09:40 PM   #950
C10_ustacould
Thanks Brian, There's a lot of progress over your way. Keep up the good work!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
