Old 08-28-2013, 12:41 PM   #1
Jayschevy
Porterbuilt Hood Hinge Question
I have the kit with gas assist I got for my 71. I installed the everything, got it adjusted and aligned. Than I couldn't get the hood open enough to get my hand under it to lift it up. Did I do something wrong?
How are you guys getting the hood to pop up enough so you can lift the hood open?
Jayschevy is offline   Reply With Quote
Old 08-29-2013, 05:48 AM   #2
Square_78
Square_78's Avatar
Re: Porterbuilt Hood Hinge Question
On my truck I have to lift up on the front GMC emblem to open it. Mine barely pops up at all. I am still running stock hinges. Did yours work better before you changed hinges?
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 08-29-2013, 07:35 AM   #3
Jayschevy
Yes the stock hinges worked fine. Just needed to go lower
Old 08-29-2013, 08:28 PM   #4
Jayschevy
Nobody has the PB hinges?
Old 08-30-2013, 09:26 PM   #5
Jayschevy
Well I left a message with Porterbuilt yesterday but haven't gotten a call from anyone yet. Needing to drive my truck tomorrow, I decided to try and use a spare set of shaved door pushers I had left over from another project. They worked great. They pushed the hood up just enough to allow me to get my fingers between the hood and grille. This allowed me to get under the hood to lift it.
I'm not sure why I couldn't lift my hood after installing the PB hood hinges but at least it's working now[IMG][/IMG]
[IMG][/IMG]
Old 08-30-2013, 11:55 PM   #6
bruin_d
bruin_d's Avatar
I'm sure Nate will get back to you. He has always been VERY good at returning my phone calls even on weekends. I have those on my Suburban and haven't had any issues. Looks like your fix is a pretty good idea though!
bruin_d is offline   Reply With Quote
Old 08-31-2013, 01:18 AM   #7
Jayschevy
Yea I'm sure he'll get back with me sooner or later but I had to come up with a quick fit if I wanted to go to a show tomorrow.
Old 09-01-2013, 10:49 PM   #8
Del72Chevy
Del72Chevy's Avatar
My hood is a huge pain to open...i have to wedge my fingers in there and pull as hard as possible...sometimes i have to get a 2x4 from underneath and push up. I still have not found and way to get the hood to pop open.
My Build Thread
http://www.67-72chevytrucks.com/vboa...d.php?t=531309
Del72Chevy is offline   Reply With Quote
Old 09-01-2013, 10:56 PM   #9
Del72Chevy
Del72Chevy's Avatar
stick the 2x4 in at the wheel and have someone else hit the hood release...two man job=ghetto fab
My Build Thread
Old 09-03-2013, 10:35 PM   #10
BurlyCrew
How hard were those hinges to locate to firewall and hood and get just right and mounted?
BurlyCrew is offline   Reply With Quote
Old 09-03-2013, 11:01 PM   #11
Jayschevy
Wasn't too hard to get it aligned. Since I don't have fender wells I could close my hood and mark the upper hood plate locations from underneath. Than I welded the upper plates to the hood. It's not the official way to do it but it worked for me.
Old 09-04-2013, 12:29 AM   #12
hahjoel
sounds like you have an issue with the spring assembly on the latch? I have no shock assist pb hinges and it pops up when the latch is released.
69 GMC Long Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=500284
hahjoel is offline   Reply With Quote
Old 09-04-2013, 12:31 AM   #13
thelonerife
thelonerife's Avatar
Thats the way to do it. I'll do it that way next time.
thelonerife is offline   Reply With Quote
Old 09-04-2013, 01:24 AM   #14
blackbolt
blackbolt's Avatar
I have a spring on the latch assembly that helps it pop up
blackbolt is offline   Reply With Quote
Old 09-04-2013, 04:51 PM   #15
Jayschevy
Any pics?
Old 09-04-2013, 09:42 PM   #16
rob32472
adjust your stops on the front on the grill and install new rubber hood bumpers on the fenders and it will pop right up or at least it worked for me
rob32472 is offline   Reply With Quote
Old 09-04-2013, 09:42 PM   #17
Del72Chevy
Del72Chevy's Avatar
I would also like to see a picture of this spring since my truck does not have one
My Build Thread
Old 09-07-2013, 08:59 AM   #18
eduardotule10
hi guys!! I have one question, is that mod expensive?? I really hate my hood hinges, I can't get them to work properly, they have already fixed 'em 3 or 4 times and I'm just waiting for the fifth time. Do you know a site that sends parts to Mexico?? And is it possible they don't charge me more money for delivery than the part itself?? thanks!!
eduardotule10 is offline   Reply With Quote
