09-08-2013, 10:43 AM | #1 |
Msd-6 ?
MSD 6 ignition boxes, are they worth the money on a stock V8 motor? How many of you guys are running them? Are they prone to failure? Thanks!
09-08-2013, 01:41 PM | #2 |
Re: Msd-6 ?
I buy them all the time at swap meets when i see them, $20-50 if dor nonither reason than they replace the troublesome module in hei dists. I have never had one fail and even the crusty used ones i bought still worked. They seem to make the engine start easier and keeps the plugs cleaner. Maybe a mile per gallon better mileage.
Posted via Mobile Device |
09-08-2013, 02:51 PM | #3 |
Re: Msd-6 ?
Thanks for the reply! I guess if it makes the truck easier to start, it might be worth it. I never know if my truck is going to start or not! lol.
09-08-2013, 03:46 PM | #4 |
Re: Msd-6 ?
It wont fix fouled plugs low cranking compression or other engine issues but it gives spark for a longer duration.
09-08-2013, 05:33 PM | #5 |
Re: Msd-6 ?
I put one in my CJ with a 304 and it made a difference in starting, accelerating is better and probably burns fuel better. It also had HEI before.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
09-08-2013, 06:29 PM | #6 |
Re: Msd-6 ?
Thanks Husker!
I am looking at taking the guess work out of starting, I would go HEI, but mines a 4WD and there's no room. |
