Old 09-10-2013, 09:36 PM   #1
BearCustom10
Unhappy 1972 Chevy Custom 10 Turn signals
Hey guys, on my truck the turn signals did not work when I purchased it, so I replaced the turn signal switch and they still don't work but the flashers work just fine. I don't know if this is a ground problem or not. I have noticed that when the lights are on, the left front will light up. Any help would be greatly appreciated.
BearCustom10 is offline   Reply With Quote
Old 09-10-2013, 10:14 PM   #2
ole dollor
ole dollor's Avatar
Re: 1972 Chevy Custom 10 Turn signals
I would start with checking the bulbs and make sure they are good , and clean , bulbs and sockets, grounds are real important , also check all wiring connections at all bulbs , frame wiring , get a good test light and jumper wire and start testing all above...good luck on your truck.
ole dollor is offline   Reply With Quote
Old 09-10-2013, 10:25 PM   #3
Wrenchbender Ret
Check the other flasher. The 4 way has its own flasher.
Wrenchbender Ret is offline   Reply With Quote
