Closed Thread
Old 09-13-2013, 08:49 AM   #8476
bill2509
bill2509's Avatar
Re: What did you do to your truck today?
Vin, checked out your truck in your photo bucket, Man that is an awesome truck, Great Job!!
bill2509 is offline
Old 09-13-2013, 11:57 AM   #8477
vin63
It's Better With Nitro
vin63's Avatar
Thanks! This rebuild iteration should've been completed by now, but been paying more attention to the funny car project the last four years.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 09-13-2013, 02:02 PM   #8478
Grizz1963
Grizz1963's Avatar
After work today I went down to the garage to check something out that has bugged me for a while.
The truck has some white plastic panels along the bottoms of the doors, and when I bought it, my suspicion was that they were covering holes. Presumably speaker holes. But you could not feel it, as the plastic is quite thick.
Ideally I would be happy with intact all steel door panels, but hey..... if the holes are there..... make lemonade.
Et Voila !!!!
Test fitted the 6 X 9 200 Watt speakers I had hidden for a rainy day and even the mounting holes correspond.
I also have an amp in the garage that I gave to a friend a few years ago, along with a 12 inch Sub, which should drive the pair of 4 ways quite adequately.
Of course there are also a pair of speakers mounted in the "B-Pillars" behind my head, but I will be leaving them alone. Along with the 400 Watt speakers in the doors, it will be way more noise than I need.
Over the weekend I have a few bits to do, including going to see a guy about airbrush painting a skull.
I may pop over to Martins, as he is in the electronics game and I want to fit a beeper inside the cab to my indicator, so that I can remember to switch them off after I go around a corner.
He also has rubber grommets which he uses in his daily job, or removes from customers cars, so maybe fit some when fitting the speakers in the doors.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 09-13-2013, 03:40 PM   #8479
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Always wanted to speakers in that location.. How don't hey sound? What size speakers do you have?
Sick5 is offline
Old 09-13-2013, 04:00 PM   #8480
Grizz1963
Grizz1963's Avatar
Not sure what you mean, as the description mentions 6 X 9 speakers with 200 Watt in the doors, still to be fitted, but if you mean the ones in the B-Pillars, I guess they are 6 inch and no more than 40 Watts each
They sound OK, perfect for being parked up only.
Old 09-13-2013, 07:04 PM   #8481
TJ's Chevy
TJ's Chevy's Avatar
Finished priming my new-to-me hood for the truck. Plan to put it on tonight.
TJ's Chevy is offline
Old 09-13-2013, 07:11 PM   #8482
donthekawguy
donthekawguy's Avatar
Finally got all the wood cut for my bed. I still have to put the urethane on 4 boards which I will do tonight after work. They will be dry in the morning and I'll start putting the bed back together. I ended up using spruce with a light pine stain and three coats of Minwax semi gloss urethane. The strips are powder coated matte black and I have all new bolts. I'm not looking forward to putting it together but if my son shows up to help it shouldn't be too bad. At least I won't have to get up and down a hundred times to get it done.
66 shorty
donthekawguy is offline
Old 09-13-2013, 07:15 PM   #8483
endlessearth
endlessearth's Avatar
How about a little foreshadowing. Look! Oh my gosh. What is that there in the trunk next to the women's bag?
endlessearth is offline
Old 09-13-2013, 11:10 PM   #8484
earl84
Got some more of the AAW wiring harness installed. Apparently I actually installed the engine stuff correctly because it started and ran
Of course, this was after figuring out that for some reason my fuel pump no longer worked. It was all fine when I last ran it several months ago, but when I tried to crank, no fuel was flowing. Changed that out, then it fired right up. Now on to the headlights (and relay upgrade while I am at it) then tail lights, put the bed back on and I can drive again. Yeehaw!
earl84 is offline
Old 09-13-2013, 11:11 PM   #8485
TJ's Chevy
TJ's Chevy's Avatar
Decided to put the new-to-me hood on the truck today.
Old 09-13-2013, 11:13 PM   #8486
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Always wanted to speakers in that location.. How do they sound? What size speakers do you have?
Lol how don't hey sound in that location in the pillars and what size speaker is it
Sick5 is offline
Old 09-13-2013, 11:14 PM   #8487
TJ's Chevy
TJ's Chevy's Avatar
If that's a 5 speed manual I'll be jealous!LOL!
Old 09-13-2013, 11:43 PM   #8488
endlessearth
Time to get jelly my man. TKO500 right there. Its going to cut the time from the barn to the feed store and back in half.
Old 09-14-2013, 09:29 AM   #8489
19666Trucker
19666Trucker's Avatar
When you going throw that in
19666Trucker is offline
Old 09-14-2013, 11:42 AM   #8490
endlessearth
The current plan is to have it in before the Good Guys Southwest Nationals.
Old 09-14-2013, 01:52 PM   #8491
joedoh
joedoh's Avatar
How do they sound?
probably like
just kidding. although I hope you have them faded to the doors.
joedoh is offline
Old 09-14-2013, 03:29 PM   #8492
19666Trucker
Cool rolling the pavilion s later you going again, get practice park lol,
Old 09-14-2013, 03:35 PM   #8493
19666Trucker
Mmmm funny car or truck, I would playing with funny car to
Old 09-14-2013, 04:39 PM   #8494
gixxer711
Taken longer than a day, but pretty much finished up. A little before and after.
Danny
64 C10 SWB fleet
gixxer711 is offline
Old 09-14-2013, 04:39 PM   #8495
TJ's Chevy
TJ's Chevy's Avatar
Made a home made sifter and used it on the truck today. Works pretty good, dump dirt on it with the bucket a the tractor and move it around with the shovel, while dumping the rocks off the side.
Old 09-14-2013, 06:34 PM   #8496
endlessearth
I am not sure yet. A lot of lightning and dark clouds coming in from the north right now. I think we might see some weather here before the day is done...which would be good if it broke the humidity. I do need the parking practice though. I don't want to get scolded again.
Old 09-14-2013, 07:47 PM   #8497
19666Trucker
I going heading over around six
Old 09-14-2013, 09:31 PM   #8498
19666Trucker
Old 09-14-2013, 10:49 PM   #8499
donthekawguy
Got some of the wood in today. Took me 4 1/2 hours to get these six pieces in. A lot of adjusting and moving around. The hardest part was trying to hold up the cross braces and get a nut on the bolt. The bed also spread apart about 1/2 an inch so I need to figure out how to pull the inner panels together while holding the bolt in the hole and the cross brace up while putting a nut and washers on the bolt that is in the deep pocket of the brace. I wish I had a conjoined twin about now.
66 shorty
Old 09-15-2013, 12:11 AM   #8500
Chevy Fleetside
Chevy Fleetside's Avatar
I hooked up the new battery. Put on some mufflers and drove it around the block for the first time in over 6 years. Boy dose it have bugs.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Closed Thread
