Old 09-14-2013, 11:29 PM   #26
jd21476
jd21476's Avatar
Re: Something wrong...feels expensive.... Need help
Other than the nasty fluid, the rear diff seems ok. Does it takes a gasket?
1973 Chevy K20
jd21476 is offline   Reply With Quote
Old 09-14-2013, 11:29 PM   #27
jd21476
jd21476's Avatar
1973 Chevy K20
Old 09-14-2013, 11:39 PM   #28
jd21476
jd21476's Avatar
Ok, so who knows and trusts a transmission shop in San Diego?
1973 Chevy K20
Old 09-14-2013, 11:42 PM   #29
mrolds88
Looks like tranny needs some help. Maybe trans pulled for some reason and when it went back in, converter wasn't seated properly. As for the rear, yes it takes a gasket, although folks have used RTV also.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 09-15-2013, 12:12 AM   #30
INSIDIOUS '86
INSIDIOUS '86's Avatar
Originally Posted by jd21476 View Post
#2
Is that brass? If so that's the main shaft bearings getting eaten alive. Mine is doing that but still has survived to this day. Mines way worse
That would be why it doesn't want to apply reverse. It's leaking internaly
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-15-2013, 12:13 AM   #31
INSIDIOUS '86
Looks like a brand new posi to me. Add some fluid. And your good
Old 09-15-2013, 12:15 AM   #32
jd21476
jd21476's Avatar
Can anyone tell what diff I have and how much fluid it takes?
1973 Chevy K20
Old 09-15-2013, 12:16 AM   #33
jd21476
jd21476's Avatar
So you think that much metal is an issue?
1973 Chevy K20
Old 09-15-2013, 12:44 AM   #34
mrolds88
Diff is a 14 bolt. Not sure how much fluid. Good rear though.
93 K2500 xcab 6.5TD
Old 09-15-2013, 09:15 AM   #35
Corts60
Just here to tinker
Corts60's Avatar
If that is in fact a posi, you need to add gear oil plus a 4oz. Bottle of friction modifier. And do not buy the pre-mixed stuff. It is not the same. Also, as for the gasket, I use a product called "the Right Stuff". It is what most OEM's are using as well instead of paper gaskets. Much better than RTV and you can use it right away.
All these things should be available at your local parts store.
Old 09-15-2013, 10:05 AM   #36
jjzepplin
jjzepplin's Avatar
This is also the diff I have. What is it? Do I need posi lube? Was told it was a locker...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-16-2013, 01:10 AM   #37
willett
Another Day, Another Dollar
willett's Avatar
I tore the reverse band out of the case on my 400, did the same thing
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 09-16-2013, 07:27 AM   #38
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The pictures in posts number 23 and 24 look like a Turbohydramatic 350 pan to me.
Tx Firefighter is offline   Reply With Quote
Old 09-16-2013, 10:10 AM   #39
legendman
legendman's Avatar
x2 pan with one corner cut off is a th350
here is a chart
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 09-16-2013, 10:13 AM   #40
legendman
legendman's Avatar
There is a plug on the right side where the driveshaft attaches, take the plug out dump in some 90wt gear oil till it starts to come out.
Old 09-16-2013, 10:16 AM   #41
legendman
legendman's Avatar
Originally Posted by Corts60 View Post
Sorry brother, it's time to pull that tranny.
x2 it's on its way out, I had a th350 the same thing, a fluid change got me a few more miles but ultimately it ended up like this... totally smoked.
Old 09-16-2013, 02:17 PM   #42
86c20
86c20's Avatar
capt. i think i see the problem. thats alot of metal in there. if it where me i would be looing for a well built 700. a 700 is a 400 with over but they where built cheap so they dont like power same as the dodge 47re. its a 727 with over. there are a few comps out there that will build a 700 well and they are not cheap but then again no trans is
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 09-16-2013, 02:27 PM   #43
mrolds88
4L80e is the turbo 400 with overdrive. 700 was used to replace the lighter duty (lighter duty than the 400) turbo 350.
93 K2500 xcab 6.5TD
Old 09-16-2013, 03:38 PM   #44
jd21476
jd21476's Avatar
Ok, so I've been getting quotes on a trans swap from the TH350 to a 700R4 of about $2400
Is that right?
1973 Chevy K20
Old 09-16-2013, 05:39 PM   #45
86c20
86c20's Avatar
yea that would be the hd 350 i think gm called them 375. but then what is the 200r4 based off of? i was always told 700 was a 400 200 was a 350. or at least base off of them
Old 09-16-2013, 06:43 PM   #46
tlawre87
tlawre87's Avatar
Its based off the Th200 or th250.. I can't remember. Essentially the little brother to the th350. My 79 nova (250 motor) has a Th250.
Trevor
74 C20...work in progress.
04 Saturn Ion...Daily Driver
tlawre87 is offline   Reply With Quote
Old 09-16-2013, 07:05 PM   #47
legendman
legendman's Avatar
http://en.wikipedia.org/wiki/Turbo-Hydramatic
Old 09-16-2013, 07:23 PM   #48
clinebarger
The HD version of a TH350 is called a TH375B, An extra friction in the Forward & Direct drum is the only difference worth mentioning. A light duty version called a TH250 also existed.
A TH375 is a light duty version of a TH400....Fewer clutches & 27 spline output. The HD version of the TH400 is a TH475/3L80-HD.
The 4L80E is based on a TH400.
The lower-end (Center support & down) of a 700R4 is the same as a TH350, The rest of the 700R4 is a "Clean sheet design". Though the front pump is a off shoot of a 2004R.
The 2004R is loosely based on the TH200, The Low/reverse, Direct, & Forward clutch assembles are a lot alike.
clinebarger is offline   Reply With Quote
