09-11-2013, 11:01 AM | #1 |
Radiator choices for LS1
What is the consensus on the best radiator to use for an LS1 swap in a AD truck? I've heard good things about Champion, but wonder if a crossflow radiator out of a newer car/truck woudn't cool the motor better and give room for dual fans?
I was considering this route for my new project: choose a 31 x 19 crossflow radiator, remake the core support to accept it and lose the inner fenders. I had all kinds of problems keeping my kids 48 cool in traffic this summer, and I don't want to build another that you have to eyeball the temp gauge in town all the time.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
09-11-2013, 08:17 PM | #2 | |
Re: Radiator choices for LS1
09-11-2013, 08:30 PM | #3 |
Thanks, that's 1 vote for Champion... What efan are you using? Is it shrouded? Could you post a pic?
09-12-2013, 02:23 PM | #4 |
09-12-2013, 03:35 PM | #5 |
I also have a champion radiator, currently running a mech fan original to the 5.3 that's swapped in. Even without a shroud mine still cools fine in hot weather. I'll be adding a shroud when the a/c gets done but otherwise it has been fine.
You'd have a fun time making up the brackets for the cross flow. Have to find a way to hang the fenders if you lose the inners completely or cut them up quite a bit. Posted via Mobile Device
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
09-12-2013, 06:35 PM | #6 |
Thanks for the input, I found a thread where someone had used a 19x22 crossflow from Griffin that fit in the original core support. I assume the Champion is an upright style radiator and not a crossflow?
09-13-2013, 07:55 AM | #7 |
Yes, upright. Haven't seen a cross flow that fits original mounts. Nice.
09-13-2013, 08:12 AM | #8 |
Here's a link to the build thread, not sure if anyone has real world driving experience with this rad or not. http://67-72chevytrucks.com/vboard/s...=384736&page=2 What I'm concerned with is the power steering box clearance. Using a 71 Camaro clip, so same issues arise as do the S10 swap. This Griffin allows me to remove the lower portion of the support for clearance.
09-13-2013, 04:42 PM | #9 | |
Pay no attention to the rusty Dex-cool all over it, that stuff was messy! To fit the radiator I did have to do slight trimming to the engine side of the radiator support, but it did fit. Clearance around the steering box was just about right:
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler Last edited by BlueJeep; 09-13-2013 at 04:48 PM. |
09-13-2013, 11:48 PM | #10 |
Thanks BlueJeep. That's exactly what I was looking for. I really like the way that radiator fits and the fact that it's a crossflow. I was reading your build, but didn't realize that you had it on the road already. Great to know that it works well!
09-14-2013, 02:38 PM | #11 |
I did have it on the road, but it's not now. I bought it in 2009, built it the winter of 09/10 and drove it the summer of 2010. Then that winter I tore it apart to fix some things....and some more things...and as a result it hasn't been back on the road since.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
09-14-2013, 04:43 PM | #12 |
cross flow or stock radiator, without a shroud expect some over heating when your in stop n go traffic.
add a shroud and use the full cooling area of your radiator.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-14-2013, 09:14 PM | #13 |
I have a full shroud on the kids truck, and it runs at 185 on the highway, but around town gets to 200deg. I am not comfortable using the AC in town as long as it's doing that. I have an aluminum rad, aluminum water pump, and a 16" Hayes electric fan that runs (relayed) whenever the ignition is on.
09-14-2013, 11:09 PM | #14 |
I have a stock 5.3 ...I've had no cooling problems with a down flow "Wizard" rad. stock mechanical fan, no shroud. 197 degrees going down the hiway. goes up to 207 with AC on, windows up idling around the fair grounds in 100 plus degrees.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
09-15-2013, 09:43 AM | #15 |
Looks really nice, very clean installation.
