Old 09-12-2013, 10:00 PM   #1
Campbel45
Inlinetube my only option for 4x4 brake lines?
Basically what the title said. Are all of you guys going to inlinetube for 4x4 brake line kits?
Campbel45 is offline   Reply With Quote
Old 09-12-2013, 10:38 PM   #2
vectorit
What?
vectorit's Avatar
Re: Inlinetube my only option for 4x4 brake lines?
I did my own.
But, I did go to Inline tube for my rear e brake cables.
They do good work, but their shipping costs and policies are not something to be desired.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-13-2013, 02:35 AM   #3
andrewmp6
I think its them or bend your own lines.
Old 09-13-2013, 12:14 PM   #4
swamp rat
swamp rat's Avatar
I just Googled "Pre bent brake line tubes" and got this.
http://www.classictube.com/resources...m-classic-tube
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-13-2013, 10:53 PM   #5
argonaut
argonaut's Avatar
Not worth the price. Get lines at your local parts store and a $5 bender from harbor freight and bend your own.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 09-14-2013, 11:20 AM   #6
russgt
russgt's Avatar
I have inline tubes stainless kit on my K5 and its a nice kit. Just installed their disc/disc prop valve but haven't driven the truck yet.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 09-15-2013, 12:17 AM   #7
Campbel45
I think thats what I'm gonna end up doing
Old 09-15-2013, 01:32 PM   #8
mjensen
mjensen's Avatar
Bent my own here. Got the Eastwood bender and their 25' coil of brake line. Worked pretty good.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 09-15-2013, 03:04 PM   #9
argonaut
argonaut's Avatar
Nice work mjensen
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 09-15-2013, 04:28 PM   #10
'63GENIII
'63GENIII's Avatar
Beat me to it Jason! Very nice work indeed. I got my front 4x4 e brake cable from Napa but I think that they outsourced it from Inline. While the quality is good, it wasn't 180 bucks good. I would bend my own lines. As seen here, you can do your own high quality lines on the cheap!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 09-15-2013, 04:28 PM   #11
russgt
russgt's Avatar
That is a very nice/clean job.
I think it boils down to the flaring part. Personally, I hate flaring lines so I went with the kit, however, if you are good at it, you can save yourself alot of money.
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 09-15-2013, 07:11 PM   #12
mjensen
mjensen's Avatar
Thanks all. A quality flaring tool is definitely worth the money. I just used a cheapy one from O'Reilly Auto. If you make sure to lube the end first it first, it will do the job.
Mike
Old 09-15-2013, 10:59 PM   #13
swamp rat
swamp rat's Avatar
I hope the one i got from Sears is a good one, After i got it i was left wondering if i got the correct degree flair?? and maybe i got the wrong kit?
http://www.sears.com/craftsman-45-de...5000P?prdNo=19
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-15-2013, 11:07 PM   #14
mjensen
mjensen's Avatar
Nope...for stock applications that is the one you want. Make sure to practice on some scrap, make sure to chamfer the end, then hit it with some sort of lube. I can't remember what I used on mine, but it was a thicker consistency than WD.
Mike
Old 09-15-2013, 11:22 PM   #15
swamp rat
swamp rat's Avatar
Thanks for the tips!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-16-2013, 09:00 PM   #16
Campbel45
Wow very nice job mjensen!
Old 09-16-2013, 10:34 PM   #17
mjensen
mjensen's Avatar
Thanks! I really appreciate the compliments. Now, if I can do it...anybody can
Mike
Old 09-17-2013, 10:36 AM   #18
argonaut
argonaut's Avatar
I used the craftsman flaring tool as well. I keep it lubed with grease and so far so good after doing stainless lines on two trucks. You can get a couple size benders from someplace like harbor freight. But they dont do as well on larger diameter stainless lines, like my 3/8" fuel line, because the stainless steel is much harder. Mild steel lines should be much easier.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 09-18-2013, 03:22 PM   #19
OrrieG
OrrieG's Avatar
NAPA also has pre flared brake lines with fittings starting at about 1' and going to 6' or so. I got an old school flaring tool at a retired machinists yard sale and went to town. Russell sells braided stainless for the hardline to caliper and rear tee connection. Look in the early part of my build thread for details. I used the same except 3/8 for gas line. I tossed my cheap bender after it messed up some bends and spent the money on a quality one that bends up to 3/8 with no kinks.
