Old 09-16-2013, 12:50 AM   #1
swamp rat
swamp rat's Avatar
Gasket?
There was a gasket between my old power booster and master cylinder, i got a new setup previously and the auto parts store didn't say i needed one then and there wasn't one in ether box so I called and they said it wasn't necessary and if i wanted one i'd have to make one.
I understand there is nothing to seal, i'm probably more concerned about affecting the throw of the lever or possibly vibration.
Tho's who have the know, is a gasket necessary at all?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-16-2013, 01:01 AM   #2
Mister-B
Re: Gasket?
It doesn't effect the angle of the push rod or vibration. It's really in there tight. I think it is mainly there to keep water/exhaust from coming inside the cab. It probably isn't the end of the world if you don't have one, but it would be best if you did. I found one at the junk yard
Mister-B is offline   Reply With Quote
Old 09-16-2013, 01:30 AM   #3
swamp rat
swamp rat's Avatar
Re: Gasket?
Its not on the firewall, it was between the master and booster
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-16-2013, 01:34 AM   #4
Mister-B
Re: Gasket?
Sorry. Misunderstood. I can't remember if the booster I just installed had a gasket or not between it and the MC
Old 09-16-2013, 01:36 AM   #5
leddzepp
Moderator
leddzepp's Avatar
Re: Gasket?
I have never had a gasket between the master cylinder and brake booster on my trucks, fwiw. I do not know if there is supposed to be one there, but I suspect not.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-16-2013, 07:31 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Gasket?
I've never seen one between master cylinder and booster.
Tx Firefighter is offline   Reply With Quote
Old 09-16-2013, 08:41 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Re: Gasket?
^Me neither -and I've replaced several on these old trucks. Personally, I would prefer not to have one there. If the m.c. piston seal were to start leaking, you wouldn't notice it as quickly.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
