09-16-2013, 09:39 AM | #1 |
Unplanned engine/tranny swap - help?
So... I let my friend borrow my 1965 GMC 1-ton flatbed (305V6).
He called yesterday nearly crying. Apparently ran it out of oil. So... a SBC/700R I have is what I intend to swap in. I did a brief search here on the swap and found some info on a 67 swap. Are the motor mounts the same? Available here? THANKS!
1952 Chevy COE - 'Brewtus' 1948 Chevy COE 1965 GMC 1-ton flatbed 1967 Corvette for those 'need for speed' times... |
09-16-2013, 02:32 PM | #2 |
Re: Unplanned engine/tranny swap - help?
You planning on using the truck as a 1 ton? Reason I ask is that might consider the 700R4. If you are looking for OD try a 4l80e. Use harness from a 90-93 diesel.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
09-16-2013, 03:01 PM | #3 |
It is just a driver now, no longer a 'work' truck. It might haul some beer but nothing heavier. I have a 700R but I think a friend has a 4L...
09-16-2013, 09:44 PM | #4 |
Are the motor mounts the same for 65 and 67 or are you asking are they the same for V6 and V8? Not that I can say for sure either way. But,I do know the frame stands are different between V6 and V8
09-17-2013, 10:46 AM | #5 |
Asking if the V8 swap is the same for my 65 as in the 67 that I found info about.
I believe I can find a factory trans crossmember from 63-87 and move it back on the frame, drill it, and bolt it in.
