Old 09-15-2013, 10:18 PM   #1
Brave71
71 chevy swb step side
hi guys .. I am new guy to 67-72 Chevys ... Just bought a 1971 chevy swb step side.. The title vin number matches the vin umber on the frame, but the plate vin on cab does not match . How bad did I screw up? Any help out there?
Brave71 is offline   Reply With Quote
Old 09-16-2013, 01:36 AM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: 71 chevy swb step side
Does the title match doorjamb?
John
1999 Toyota Tacoma 4x4
Old 09-16-2013, 03:28 AM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Two thoughts,
1. If your DMV goes outside and checks it before you register it you are SOL. You are going to have to go to the DMV and have both VIN's ran through and apply for a new title/VIN. This can be a pain and if the seller doesnt want to help you, you may be in for a bad time.
2. If the DMV doesnt check it and it was titled in the same state, you may be fine, but then you will have to deal with it if you ever want to sell it. If you do get it in your name then you may be able to get a new title with a new VIN and all could be well.
Always check frame, VIN, glovebox SPID and title before buying. If the SPID is readable, you will know if someone is trying to sell you a cutdown longbed as a shortbed.
All depends on the DMV, could be painful, could be easy.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 09-16-2013, 03:51 AM   #4
In The Ten Ring
So, if I buy a cab without a title, what is the best course of action?
In The Ten Ring is offline   Reply With Quote
Old 09-16-2013, 04:00 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
The title needs to match the door jam vin... if it doesn't, you have issues. The door jam vin is attached with 4 special rosette rivets to identify if any tampering has coccured. If the DMV thinks there has been tampering OR the paper title doesnt match the door jam the police will become involved and the truck may be impounded.
Whats the story from the person you purchased the truck?
PS:
If it's a Nevada title, they dont check the vin at the inspection station. If its an out of state title the will verify the door jam vin and sometimes check the frame vin.
Rich
1972 K5 Blazer CST Click HERE
Old 09-16-2013, 10:27 AM   #6
Brave71
Thanks for your help. What if a person got a frame and found a cab somewhere then pieced a truck together? How would you go about getting a title?
Old 09-16-2013, 10:34 AM   #7
mcmlxix
mcmlxix's Avatar
Each state tends to follow their own rules. I would go to the DMV and talk to the inspectors, not the people at the window. I do know that for this era trucks, the door jam tag must match the vin on the title... the frame SN is a grey area and like I said... NV title and no one looks... Out of state title on a running drive clean looking truck, probably not going to check the frame. Multi colored panels and missing inner fenders or bed parts may flag the inspector to look more closely... Then again, go on a Monday and you get the third degree.. Go on a Friday and you get... ehhh, that good enough...
Rich
Old 09-17-2013, 12:54 PM   #8
Brave71
I live in Nevada , so I'm thinking I will buy a cab with NV title and use all the other parts from the truck I bought in CA. Then I will have a NV title for the cab and a CA title for the frame .Now what problems do I have? I also saw a web site that sells the special rivets ?
Old 09-18-2013, 04:07 AM   #9
mcmlxix
mcmlxix's Avatar
Find a 67 Cab... no smog check in Clark County....
Rich
Old 09-18-2013, 09:31 AM   #10
Tinkermc
Welcome to the Forum. Sorry to hear about your troubles.
Tinkermc is offline   Reply With Quote
Old 09-18-2013, 09:59 AM   #11
71sierragrande
Petroleum User
71sierragrande's Avatar
My door jamb plate had been removed yrs ago by the PO. When I went to DMV, the inspector said, "I can't find a VIN number on this thing". So I said, "oh, there's one inside the glovebox". He looked at it and passed me, you might get lucky like I did.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 09-18-2013, 10:20 AM   #12
Brave71
Mcmixix. Why 67 cab .. I would like to get a 72 cab..
Old 09-18-2013, 05:07 PM   #13
mcmlxix
mcmlxix's Avatar
Any vehicle, 1967 and older is exempt from smog check in Clark County (I think Henderson is in Clark.) Any vehicle 1968 and newer still requires to be checked with an emissions test every year. Its just one less thing to worry about....
Rich
Old 09-21-2013, 08:02 PM   #14
Brave71
I called a guy in Vegas, Don at dons classic chevy parts .. He told me how to get my title , seems Nevada is a frame state , the vin tag on my truck magically disappeared? Took the truck to DMV .. Got lucky with a really nice inspector, he checked the frame , numbers matched. Then he installed a new vin plate..( blue tag) title to me is on the way.!!!
Old 09-21-2013, 08:16 PM   #15
chiefcfd
chiefcfd's Avatar
That is good news. Glad to hear it turned out ok.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
