Old 09-16-2013, 11:56 PM   #1
oscary
Unhappy suspension squeaks
Have a 75 cheyenne pickup that runs great. Squeaks like he'll when your coming down the street, even on a smooth road. Had the chassis lubricated, but still squeaks. Heard its probably bushings but there are so many of them. Does anyone now which ones are prone to squeaking. Any advice would help.
oscary is offline   Reply With Quote
Old 09-17-2013, 12:30 AM   #2
lha1992
lha1992's Avatar
Re: suspension squeaks
have you had the ball-joints greased? Control arm bushings for upper and lower? Tie rod ends greased?
lha1992 is offline   Reply With Quote
Old 09-17-2013, 12:39 AM   #3
Ziegelsteinfaust
Are your shocks tight?
Ziegelsteinfaust is offline   Reply With Quote
Old 09-17-2013, 03:25 AM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
You can drill and install zerks in the control arm bushings. Lube the sway bar as well. Those are the common areas
Otherwise have a hyperactive friend bounce on your truck and listen where it's coming from
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-17-2013, 08:22 AM   #5
Rich84
Rich84's Avatar
Mine squeaks a bit as well..Coming from the back. Must be the leaf spring bushings. They are all new.
Can you just spray some lube in there?
Rich84 is offline   Reply With Quote
Old 09-18-2013, 12:23 AM   #6
oscary
Only have had the chassis lubricated. Will look into the ball joints, and control arm bushings. Thanks for the advice
Old 09-18-2013, 12:28 AM   #7
oscary
Don't know how to check if shocks are tight. They are about 20 years old though
Old 09-18-2013, 01:18 AM   #8
INSIDIOUS '86
Shocks can squeak too. Mine do on the stepside right now
Old 09-18-2013, 05:06 AM   #9
andrewmp6
If the shocks are really 20 years old they are probably long past shot.
