Old 09-17-2013, 08:07 AM   #1
bojak
bojak's Avatar
Wheel spacers for 8 lugs
Does anyone have knowledge about 8 lug wheel spacers? From a looks perspective I think it may look better to space my rear wheels out a little. Not get them equal to my front, but not as much difference. Don't know anything about them though. Do they negatively effect the strength or make it less durable? Any help is appreciated.
bojak is offline   Reply With Quote
Old 09-17-2013, 09:23 AM   #2
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Re: Wheel spacers for 8 lugs
First, you need to figure out how wide you want to space them out. As a rule of thumb I don't like to use any wider than 3/8" or so of a slip on spacer (make sure you use machined billet aluminum or steel in this case DO NOT use the cheap cast aluminum spacers available all over). You will want to measure your studs, wheels, and the spacer thickness to ensure you will have enough thread engagement, you want to have a few threads sticking through the lug nut if open ended, or at least enough threads to equal the diameter of the stud engaged in a closed lug nut.
From there it jumps up to about 1" minimum thickness for bolt on spacers, although I prefer to go no thinner than 1.25", but likely you will have to cut your studs for spacers this thin as the studs themselves are longer than the spacer thickness. Measure your studs to be sure how thin you can go, and if you are willing to cut the ends of the studs off or not.
As far as the "effect on strength and durability" I could write a book on all the pros, cons, and misconceptions of them.
If you buy quality spacers and torque them down properly you will never have issues. GM, Ford, and Dodge (and other manufacturers) use them in both slip on and bolt on form from the OEM. Think of it this way, the inner rear dually wheel, floating drums, and floating slip on brake rotors are no different than a slip on wheel spacer between the wheel and the hub. Bolt on brake rotors and bolt on OEM dually front hub adapters are nothing more than bolt on wheel spacers.
Do they increase the leverage or stress on the wheel studs? No, your wheel studs do not support any weight of the vehicle. If they do then your wheel is not properly torqued down. Every ounce of the weight of the vehicle is supported by the friction created by the clamping force holding the wheel flange to the hub flange. The only force on the studs should be tension from torquing the lug nut.
Do they increase the leverage and therefore the hub bearings? Yes, of course, that is the nature of the beast of moving the applied force further away. BUT it is absolutely no different than adding wider, more offset wheels. Think of it this way, consider a stock 6" wide wheel with 4.5" of backspacing. Now swap to another 6" wide wheel with 3" of backspacing. The end result is identical to using a stock wheel with a 1.5" spacer which results in the exact same overall backspacing, and therefore leverage on the bearings. Now then if you added a wider wheel at the same time as decreasing the backspacing (for a wide, offroad look) you are actually making a worse scenario than the wheel spacer.
I have ran them for years on several different trucks, 6 and 8 lug, play toys and heavy haulers. I have never had one issue. If you have any specific questions about them I'd be happy to answer them. I could have gone into much greater detail above, but I felt it was already long enough as is.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 09-17-2013, 07:29 PM   #3
bojak
bojak's Avatar
Thanks for the good info. Does anyone have a recommended vendor or manufacturer for quality spacers?
Old 09-18-2013, 09:35 PM   #4
v30crewcab
v30crewcab's Avatar
make sure whatever ones you get you check to make sure they run true. my 2" ones I got from ebay do not. probably going to have to buy another set cause I really like the dodge rims on my truck, and can't find any other rims I like. I also have a set of 3.5 spacers, that I used to run dually wheels on the front. never had any problems. just get quality ones.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is online now   Reply With Quote
Old 09-19-2013, 07:47 AM   #5
GCncsuHD
GCncsuHD's Avatar
I have had good luck with seller tireshopsupplies on ebay, I've bought 3 sets from him and each set has been great. EZaccessory and Motorsport Tech both make quality spacers, but I had terrible customer service from both, YMMV. Fred Goeske (google him) makes probably the best, but his price reflects it.
ΜΟΛΩΝ ΛΑΒΕ
Old 09-19-2013, 08:30 AM   #6
v30crewcab
v30crewcab's Avatar
tireshopsupply is where I got the current ones, which none of them run true. not sure what happened, but it took me a long time to realize it was the spacers. integrity-automotive looks to have a nice set, at a few dollars cheaper as well.
71 longbed 5.3 4l80
Old 09-19-2013, 10:08 AM   #7
bojak
bojak's Avatar
V30 - Since I see you are running a similar truck as mine, what size spacers are you running? I know you said you have some 2" but you also said you have some 3.5" ones. Does that equal the same width front and back? Just trying to get your notes to save myself some head scratching. Thanks
Old 09-19-2013, 11:36 AM   #8
zellway
zellway's Avatar
http://billetwheeladapters.com/
I have a set on the back of my 3/4 ton 67. been on for the past 50k and still working fine. My truck gets beat on more then I like and they have held up.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 09-22-2013, 12:22 PM   #9
v30crewcab
v30crewcab's Avatar
I use the 2" front and rear. the 3.5 were for a setup I used to run to be able to switch between single and duallys.
71 longbed 5.3 4l80
