Old 09-18-2013, 07:50 AM   #1
FLYNAVY30
Accessory drive question
What factory accessory drive set up fits best? I purchased my LS1 as a long block so Im going to have to do some junk yard searching so I wanted to verify whether the truck, Camaro/GTO, or Corvette accessory drive fits best for a 72 C20. Im also going to be running a Vintage AC system so Im going to need to purchase the appropriate adapter bracket for the compressor based on what accessory drive set up I run.
Thanks for the help.
FLYNAVY30 is offline   Reply With Quote
Old 09-18-2013, 08:46 AM   #2
68Stepbed
68Stepbed's Avatar
Re: Accessory drive question
It mainly depends on which intake you plan to use. The truck accessory drive systems are the most plentiful and easy to find. They also use a Saginaw power steering pump which is easily adaptable to run with the stock steering box. The biggest issue with them, though, is the idler pulley interferes with the intake ducting on Camaro/Vette intakes. This is easily remedied with an idler relocator. At this time, I can't remember who makes/sells them.
The F-body, Corvette, GTO, and CTS-V systems are harder to come by in junkyards, but can be found in the classifieds section at www.ls1tech.com.
Keep in mind that each system uses different balancer pulleys, so if you get something from a junkyard, be sure to get everything from the front of the engine. The balancers require a special puller, so if you don't have one, getting a previously removed used, or even a new balancer may be easier.
As for which one fits best, well, they all fit inside our trucks just fine. The only major modification will be adapting or making power steering lines and possible frame notching for the low mounted a/c setups.
Dirty Dingo and Holley make some nice a/c compressor brackets that relocate them to the top, though.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-18-2013, 10:32 AM   #3
FLYNAVY30
Thanks for the info, I'm running a carb so the intake clearance isn't an issue. I'm also running vintage AC so Im going to need an adapter for the compressor regardless. Good info on the power steering pump.
Old 09-18-2013, 10:38 AM   #4
Hart_Rod
Hart_Rod's Avatar
Holley LS brackets....
Hart_Rod is offline   Reply With Quote
Old 09-18-2013, 10:59 AM   #5
smoky02
Location: Sunny, Florida, some might call it South Alabama
You just wanted to show off that big super charger Rob...lol
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 09-19-2013, 07:44 AM   #6
FLYNAVY30
awesome....what model did you get the water pump and the crank damper from? Also, what power steering pump are you running?
Thanks!
Old 09-19-2013, 08:57 AM   #7
Hart_Rod
Hart_Rod's Avatar
Thanks!
That's the cool thing about their brackets, you can buy the spacer to match whatever waterpump/crank damper you have. Check out their website/install manual:
http://www.holley.com/data/Products/...R10613rev7.pdf
http://www.holley.com/types/LS%20Swa...y%20Drives.asp
Old 09-19-2013, 10:22 AM   #8
FLYNAVY30
Ahhhh....sweet! BTW, I've wasted a solid 2 hrs at work reading through your Suburban build thread...good stuff!
Old 09-19-2013, 11:05 AM   #9
Hart_Rod
Hart_Rod's Avatar
Hope you enjoyed it! Let me know if you have any other questions. Look in my 68 s/c thread, I have more pics of the brackets in there.
Old 09-19-2013, 01:32 PM   #10
68Stepbed
68Stepbed's Avatar
:LOL: Hope you enjoyed it! Let me know if you have any other questions. Look in my 68 s/c thread, I have more pics of the brackets in there.
So much for him getting anything done at work, now.
Matt
Old 09-19-2013, 01:56 PM   #11
FLYNAVY30
Work's over rated when you're not on the flight schedule
Old 09-19-2013, 02:00 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Work's over rated
/thread
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
