Old member
I also got the o-2 senors, oil cooler lines and all the AC lines which I don't think I will be able to use. I will be adding to this as I get stuff done.
Any suggestions comments please advise me on what I should look for are need. Looking forward to this install. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: I bought a LSX motor!
Lucky dog! Andy if I read between the lines the 71 is going to receive the transplant right?
Trueman |
Old member
Yes the 71 is getting a new heart beat! Want to have it up and running by next June before the power tour starts!
The old 305 TPI is needing a whole rebuild so I figured this would be a better way. ![]() ![]()
