Old 09-18-2013, 09:48 PM   #1
mrpaintstick
mrpaintstick's Avatar
changing rear end gear
I have a 76 c30 auto with 410 gears.I was considering changing rear gear ratio to get a little better gas milage. Was not sure which rear end I have and what options would be available. I have the original build sheet. Anyone have any experience with this?
mrpaintstick is offline   Reply With Quote
Old 09-19-2013, 12:28 AM   #2
eray92
eray92's Avatar
Re: changing rear end gear
An easy way to tell is count the bolts holing the cover on. Most likely a 14 bolt. But there are 2 types of them. It could also be a 12 bolt. Idk exactly what the c30s came with
eray92 is offline   Reply With Quote
Old 09-19-2013, 08:55 AM   #3
walkerb
walkerb's Avatar
Its most likely a Dana 70, if I remember correctly
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 09-19-2013, 11:53 AM   #4
eray92
eray92's Avatar
Forgot all about Dana's
Old 09-19-2013, 08:19 PM   #5
mrpaintstick
I will check that. Anyway to tell from the original build sheet and truck plant or did they just use what ever was available at the time?
Old 09-20-2013, 05:18 AM   #6
donut
donut's Avatar
Way I understand it.
14 bolt ff-srw
14 bolt -dual cab and chassis
Dana 70 -dual wheel pick-up
My understanding, may be wrong. By all means, check your build sheet, and/or post up a pic.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 09-20-2013, 09:21 AM   #7
walkerb
walkerb's Avatar
Donut is correct. I assumed, seeing c30, it was a Dually. So do you have a single axle or dual?
Old 09-20-2013, 11:02 PM   #8
mrpaintstick
It is a cc dually i will try and post a pic. I am trying to decifer the build sheet I will try to post a pic of it also
Old 09-21-2013, 11:20 AM   #9
donut
donut's Avatar
Don't sweat the build sheet to much. iirc, it'll show gear ratio, not necessarily the rear-end.
How tall are your tires? Rpm at speed?
Personally, On mine, the rpm range was about where I wanted it. In my case, the expense of OD or a gear change wasn't worth it.
Old 09-21-2013, 04:02 PM   #10
mrpaintstick
It has 235/85-r16 and 4:10 gears I have never put a tach in it. I figure on nver selling it and I do not forsee gas getting any cheaper. I am in a rural area would be nice to ba able to drive to the city if need be. I just got a line on a good 200r4 for $100.
The drive shaft is the only part fo the swap I would not be able to do myself.
Old 09-21-2013, 07:06 PM   #11
Keith Seymore
Keith Seymore's Avatar
I would like to see the build sheet if you can post it up.
Thanks in advance -
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-21-2013, 09:58 PM   #12
eray92
eray92's Avatar
I live in Napoleon and just swapped a 200-4r into my 82 swb and now I'm switching the gears to 4.56s. There is a guy up the road towards greensburg has a farm shop on the left who can put a new tube in your driveshaft. What trans do you have?
Old 09-21-2013, 11:46 PM   #13
mrpaintstick
I have a 350 now. Are you talking about Kunz farm repair? Is the 200r4 a decent trans? Seems most post are about swapping to a 700r4.
Old 09-21-2013, 11:53 PM   #14
eray92
eray92's Avatar
200 is a direct swap, just move your crossmember back to the 400 location. That is if its a 6 inch tail shaft. Yes kuntz is the place I think. The 200 has a taller first gear and od. I had 3.08s in there and it would cruise at 1300 rpms. I have a 383 200-4r will be 4.56s and 255/45/20s (29" tire) and my rpms at 60 will be right around 2000, your 4.10s would drop it lower. I like my 200 a lot. If you have any questions on the swap I'm just a message away. I'll tell you everything you need
Old 09-22-2013, 12:10 AM   #15
mrpaintstick
I will keep that in mind thanks a lot
Old 09-22-2013, 12:13 AM   #16
eray92
eray92's Avatar
No problem, that's what this site is for
