Re: Defrost hoses.
i used heat and they always went on an stayed in place// you could try a little bit of water on the plastic cause it will not leave a residue
Re: Defrost hoses.
There not the plastic ones there like a sticky tar paper similar to the originals.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: Defrost hoses.
heater box and dash vents are plastic
Re: Defrost hoses.
I would try some black rtv silicone...slippery to install,and once it dries it will hold them on
1970 short step c10 leaf spring 454 |
Re: Defrost hoses.
I would suggest using talcum powder (baby Powder) to get the hoses on. It will limit the stickiness, but not provide lasting lubrication. Just be careful the first time you blow air through the tubes because there will likely be a cloud of powder. I used this method for the silicone heater tubes in aircraft.
1990 Suburban Silverado 350, SM465 and 35" tires |
