Old 09-09-2013, 06:05 PM   #1
mlevario99
Exclamation Water pump outlet to heather
On the water pump for a 5.3 vortec, which of the two is the outlet for the heather, how is the water moving??
mlevario99 is offline   Reply With Quote
Old 09-09-2013, 09:56 PM   #2
truckdude239
truckdude239's Avatar
Re: Water pump outlet to heather
botgh of the 2 outlets are for the heater core i had 2 different size hoses on my heater core so they would only fit one way
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-09-2013, 11:37 PM   #3
mlevario99
Thanks truckdude, but one has to be the supply and the other the return, this engine is in a 66 truck with the 5.3 and a vintage air conditioning
Old 09-10-2013, 12:26 AM   #4
truckdude239
Okay I put mine into my 71 so one port on my heater core was larger and matched the port on the pump and same for the other one I haven't run it yet
David fuller
2000 Tahoe 5.3l 378
Old 09-10-2013, 02:49 PM   #5
Robznob11
Robznob11's Avatar
Some one may correct me if im wrong but the smaller 5/8 line is on the back side of the t stat wich tells me it is the pressure side ( also the fact that its smaller usually indicates higher press) the 3/4 is on the front side of t stat wich because of size and location tells me its a return. I also think this because you would have no flow to heater core till the t stat opened if it were the other way around. But again this is just a guess on my part lol
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 09-10-2013, 02:56 PM   #6
Special-Ed
Special-Ed's Avatar
Sorry but my engine compartment is dirty from Georgia clay and Florida sand.
Obviously one is feed. One is return.
big one = return
little one = feed
2005 suburban z71 with 5.3
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 09-10-2013, 03:02 PM   #7
Robznob11
Robznob11's Avatar
Now that im looking at you pic im thinking they both may be on the back side of t stat but i still think the 5/8 is feed. Ill see if i cant dig up the lsx water flow diagram on the net caus i used it to figure out how to plum my overflow bottle into the heater lines, this is why i keep thinking the 5/8 is feed caus it seems like that how i remember it. Im sure a guru will chime in soon
LED TAILS
Old 09-10-2013, 03:11 PM   #8
Robznob11
Robznob11's Avatar
Of chorse my phone wont let me post the image but if you google ls engine flow (images) the second one is a diagram and the back or smaller port is feed.
LED TAILS
Old 09-10-2013, 03:18 PM   #9
mlevario99
Thank you all
Old 09-10-2013, 03:23 PM   #10
Special-Ed
Special-Ed's Avatar
im not sure... i have a replacement water pump and i think my casting is bad. i have little to no heat in the truck.... not a big issue when im in florida... but i froze my azz off when i went to chicago for the holidays to hang out with my kids... its pissing me off as well... i eat about 1/2 gallon every 6 months of anti freeze... i find no leaks,(die black light) holds pressure, no exhaust fumes bubbling in coolant, no signs on plugs... but every once in a while i smell steaming coolant... thinking it may be a dodgy pressure cap.
or it could be seeping into the intake somehow and leaning out the fuel mixture but still being burned... i dont know enough about my engine to know off the top of my head every coolant port inside the motor and where they may leak.
i was the guy at the factory that dealt with quad 4's and the 3.4 twin dual ohd motors... and other assorted items for PMD...
the return seems like it needs to be ported to the other side of the tstat for flow to actually happen...
Old 09-10-2013, 09:44 PM   #11
Robznob11
Robznob11's Avatar
http://i17.photobucket.com/albums/b8...oolingflow.jpg
LED TAILS
Old 09-10-2013, 09:55 PM   #12
Special-Ed
Special-Ed's Avatar
Originally Posted by Robznob11 View Post
that picture is a wee bit off...
the return from the heater core goes directly back to the tstat housing/water pump...
it does not go back to the over flow pressure tank...
Old 09-11-2013, 01:06 PM   #13
storm9c1
*** That's interesting ***
storm9c1's Avatar
Might be interpretive, but perhaps that diagram just indicats a tee in the heater line where the pressure tank connects. I don't interpret this as meaning the heater hose goes straight to the tank.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 09-11-2013, 05:25 PM   #14
Robznob11
Robznob11's Avatar
Due to the fact the water pump in the diagram exits the wrong side i would say you are correct. But just to squash any misconseptions. I currently have no heater core in the hot rod. I did not want a short loop so i did run a tee right at the overflow and my feed runs up to it and back down. It works fine does not suck the tank dry or pump it full stays the same level. I originally had the tank plumed into the lower rad hose and for what ever reason was getting air pockets and over heating . The new pluming stays about 199* just ideling.
LED TAILS
Old 09-11-2013, 10:20 PM   #15
ls1nova71
ls1nova71's Avatar
The heater shut off goes in the small hose, the rear fitting on the engine, if that's what you're asking.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-12-2013, 08:26 AM   #16
mlevario99
Yes, that is what I was looking for, i did a search like Robznob11 suggested and found a diagram.
Old 09-12-2013, 08:40 AM   #17
cdowns
cdowns's Avatar
i have a nurse called heather she is hot but i've never seen her outlets
Old 09-12-2013, 10:46 AM   #18
mlevario99
Here is the picture I found
Old 09-20-2013, 12:50 PM   #19
Andy4639
Old member
Andy4639's Avatar
Question Re: Water pump outlet to heather
Are u guys all using the pressure tank (surge tank) in the swaps on 67-72 trucks that is posted above.?
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-20-2013, 01:09 PM   #20
mlevario99
I'm not using it
Old 09-20-2013, 01:50 PM   #21
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
That is designed for sealed radiators that use a remote surge tank (kinda like using the ps pumps that have a remote resevoir). If your radiator has a cap with a pressure rating, then your don't need that. The idea is that it keeps some extra fluid and give the fluid a place to go under. It also helps keep a full radiator since it hold extra fluid that can drain into the rad if it gets low.
Most of us have a regular capped radiator. You fill the rad, and run an overflow so it has a safe place to dump if it overheats. We would have to manually add coolant or water if the rad got low, but you also don't have to place and plumb an extra tank underhood.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-20-2013, 03:46 PM   #22
Andy4639
Old member
Andy4639's Avatar
Cool Re: Water pump outlet to heather
OK then I'm good to go I have a over flow tank already!
