Old 09-19-2013, 07:40 PM   #1
duckdude
converting to bbc question
im wanting to put a bbc into my 69 3/4t 4x4. it had a 350. I have bought the bbc stands that mount to the frame but the look like they wont mount up. my crossmember looks different from some I have seen in pictures. can anyone tell me what I need to complete this swap?
duckdude is offline   Reply With Quote
Old 09-19-2013, 09:04 PM   #2
fp1967
fp1967's Avatar
Re: converting to bbc question
I did a big block swap in a 69 4wd in 1987. I didn't need different stands, I just bolted it up to the original crossmember. The bbc stands that you bought, must be from a 2wd, which are different than the 4wd. The reason that you need different stands on a 2wd with a bbc is because the bbc exhaust manifolds won't clear a 2wd stand from a small block truck.
I used stock exhaust manifolds and if I remember correctly, some of them didn't fit and some did. I have no idea what the manifolds came off of that I used, but if I had to guess, I would say a car and not a truck. I have no idea which model car though.
The biggest problem that I ran into was the clutch linkage. On a 4wd, the clutch ball threads into the front hole on the block. The stock manifolds only allowed using the rear hole on the block. At the time, I had a 68 4wd GMC parts truck, the engine was missing, but it had V6 emblems on it. I noticed that the clutch linkage was set up to use the rear hole for the ball, so I used the clutch linkage off that truck, which required me to put a new hole in the firewall for the clutch rod to go through.
If you have any other questions, I can try and answer them for you. This is just what comes to mind right now.
fp1967 is offline   Reply With Quote
Old 09-19-2013, 09:38 PM   #3
duckdude
thank you fp1967 that helps
Old 09-19-2013, 11:52 PM   #4
SKELLY4x4
SKELLY4x4's Avatar
Hit me up for pics if you need them. I put a bbc in my 72 k20 a long time ago but I still have it and getting it ready for my kid to drive. I don't remember the details but it wasn't that easy but not that hard to put the bbc in. Time flies.
1972 chevy k20 long bed 4x4
1990 chevy K5 blazer
2001 chevy 2500 hd 4x4
1999 chevy 1500 4x4
SKELLY4x4 is offline   Reply With Quote
Old 09-20-2013, 04:07 PM   #5
duckdude
skelly any info or pictures you would want to share would be very helpful and I would be very grateful
