I got a little money to spend!
So I got a little bit of cash and I was thinking of getting rear drop springs, a notch and an adjustable track bar for the rear. Also getting the sway bar mounts for the front so that I can install the sway bar I have. I currently have TJ springs in the rear and if you set a beer can in the rear it sags.
My question is are the CPP springs gonna be the same way or can I actually load my bike in the back without the truck bottoming out? I'm not sure if Im gonna need the notch with 5 inch springs but I wanna have it in case I go lower. I currently have six lugs in the rear and five in the front so I could spend the money converting the rear but I have baby moons hiding the bolt patterns so that doesnt really concern me. Any better suggestions on how to spend the money?
BaBaBooey BaBaBooey ![]() GO SPURS GO!!! |
Re: I got a little money to spend!
I think they make "heavy duty" drop springs for towing. Stiffer ride with more weight capacity
Posted via Mobile Device |
![]() Join Date: Jan 2011
You can do rear bags with schrader valves for not much more than springs and then you're adjustable if you do carry a load.
We can help spend it...tons of ideas.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
I have a set of small bags that a buddy gave me I just wasnt sure how they'd handle any loads. They're pretty small looking. I'll post pics later.
I have 4" drop rear coil springs from CPP on mine with no problem with weight...
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
You could also use a set of rear "helper" springs... My 65 came with them.
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
I forgot, I have a small universal c notch. Is the frame on our trucks at an angle that would prevent me from using it? Its really straight.
Who Me?
I have 2500# bags in the rear of mine, no notch yet and I love the ride.. The load capacity is good too.. Check my build thread for some pics.
Steve1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
If you go with 5 inch drop you will need new shocks and a relocator kit. Hows that for "helping" spend your money?
66 shorty
Adds up so quick.
| Bookmarks |
