Old 09-21-2013, 07:40 AM   #1
adricar1
engine removal
It will be six to eight weeks before i get my K1500 as its in transit to me here in the uk.
I have a new 383 built here and i am contemplating putting in the truck instead of the 350 it has, Whats involved in removing the engine, can it be done with the bonnet (Hood) off or do i need to remove the cab. What is the easiest way to go about it.
I have no problem either way , but what way would you guys do it. And how easy is it to remove the cab complete?
adricar1 is offline   Reply With Quote
Old 09-21-2013, 08:04 AM   #2
Daddy Brim
Daddy Brim's Avatar
Re: engine removal
I would pull hood and radiator. Then the engine and transmission will come out as a unit.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 09-21-2013, 09:00 AM   #3
msgdsrf
Re: engine removal
Just went through this. Take off hood, radiator and undo fuel and power. I left tranny in as I wasn't going to work on it, so unbolted from tranny and mounts, then hoisted. Super easy. Going back in was a doddle too. I used a couple of studs in the tranny housing to line things up. Did it all without any extra hands.
msgdsrf is offline   Reply With Quote
Old 09-21-2013, 09:20 AM   #4
Ackattack
Ackattack's Avatar
Re: engine removal
I've taken an engine out of these trucks in an hour. Pretty easy.
Ackattack is offline   Reply With Quote
Old 09-21-2013, 10:01 AM   #5
67swb72klb
67swb72klb's Avatar
Re: engine removal
if you want to detail the engine compartment you can pull the front clip in one piece but its not needed
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 09-21-2013, 10:42 AM   #6
Coley
Coley's Avatar
Re: engine removal
Having done this like a lot of the other guys.....I would just remove the hood and the radiator.
If you start pulling fenders and grillls, etc you are going to find yourself into re-alignment and fender/panel 'gap' problems when you re-install this stuff.
It will all go a little easier if you use a good hoist with a tiltable connection and if you have a good flat shop floor to work around and on.
(Note: Be very careful with unbolting and then 'tieing' back the air conditioning unit so that it is out of the way. Or you are going to be rebuilding and recharging it which will be extra cost and work)
My two bits.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-21-2013, 12:17 PM   #7
adricar1
Re: engine removal
thank you guys , certainly the engine will be going in , and i may as well, reseal the autobox.
its a good point on the air con, i will see if it works when it arrives.
Old 09-21-2013, 12:45 PM   #8
geezer#99
geezer#99's Avatar
Re: engine removal
Motor and tranny won't come out together unless you unbolt the transfer case. Best to leave the tranny in there.
geezer#99 is online now   Reply With Quote
Old 09-21-2013, 05:39 PM   #9
Badger7C9F
Re: engine removal
Hey mate, I've just pulled the engine and box in one go, and that's in a U.K sized garage??. You'll know what I mean. I took the bonnet, core support, grille off, left the wings and bumper in place. Just put the the engine and box back in today, it took a couple of hrs as it was down to two of us with an engine cr ne and a minimal tool box but it can be done. Where in UK are you???
Badger7C9F is offline   Reply With Quote
