Old 09-20-2013, 06:30 PM   #1
TxRat
TxRat's Avatar
Yep, Another header question.
Here's what I'm dealing with:
Ive read a few header threads and still am not quite clear.
I want long tube headers but would like the collector to be above the bottom of the framerail so i can tuck my exhaust up and run it through the rear crossmember. I've heard Camaro headers but which one? any options out there?
TxRat is offline   Reply With Quote
Old 09-20-2013, 10:52 PM   #2
contagious102
contagious102's Avatar
Re: Yep, Another header question.
I used 72 hooker chevelle headers on my big block.They tucked in the frame nice.
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 09-20-2013, 11:15 PM   #3
TxRat
TxRat's Avatar
I should have added this truck has a 327 small block..
Old 09-21-2013, 12:43 AM   #4
Captainfab
60-66 Nut
You could possiblr use small block Chevelle headers, which should be above the bottom of the frame, However those will not work if you still have the original bellhousing crossmember.
Old 09-21-2013, 09:16 AM   #5
TxRat
TxRat's Avatar
CaptainFab,
Thanks, I do not have the original crossmember. My truck has a 700r4 trans with a tailshaft crossmember.
I'll look into those..
Old 09-22-2013, 09:07 AM   #6
TxRat
TxRat's Avatar
OK, I picked up a set of 69 camaro headers from a buddy yesterday so we could see if they would tuck up above the bottom of the frame on my 66 c10.
Before I start dismantling my truck I would like to ask if some one has a set of long tube headers for a 60-66 V8 truck hanging around could I get a measurement just to see what the over all height is.
I stood the header up against a stool and measure from the ground up to the bolt hole at the #2 cylinder on the passenger side header. I came up with 16 11/16". Thanks for the help guys...
Old 09-22-2013, 05:01 PM   #7
TxRat
TxRat's Avatar
Bump, Anyone?
Old 09-23-2013, 10:45 PM   #8
Trsmotrhed
Trsmotrhed's Avatar
I'm watching this thread also. If you end up trying them let me know. my Headers scrap bad.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 09-24-2013, 07:19 PM   #9
TxRat
TxRat's Avatar
Looks like thats what I'm gonna have to do , I can't believe no one has a set of truck headers hanging around that can take a minute and grab a measurement for me....
Old 09-24-2013, 08:09 PM   #10
Trsmotrhed
Trsmotrhed's Avatar
I can when I get back home this weekend
63 SWB C10
Old 09-24-2013, 08:23 PM   #11
TxRat
TxRat's Avatar
Old 09-24-2013, 09:19 PM   #12
TxRat
TxRat's Avatar
ok, so for the last hour I have been cross referencing threads and found this statement: http://67-72chevytrucks.com/vboard/s...28&postcount=8
that led me to this post: http://67-72chevytrucks.com/vboard/s...&postcount=281 this make reference to using 68-71 Camaro headers.
I believe they will work.
