Old 09-22-2013, 09:34 AM   #1
louaxtjr
louaxtjr's Avatar
Looking for towing/leveling advice
1969 Longbed coil sprung survivor. Factory ride height. Tow a 1966 Airstream with no problem, but the rear sags even with load bars on the hitch set up. Doesn't significantly impact the handling, but I'd like to level it out. Hoping someone with firsthand experience can recommend a solution. Looking at add-on air bags to fit inside the coils or new HD rear springs. The air bags seem like the better solution to maintain unladen ride quality, but am having difficulty finding a set for this application. Can anyone point me in the right direction?
_____________________
Lou Axt, Jr.
1969 C10 Longbed 292 inline 6 Offy, Holley, true dual exhaust
tows a 1966 Airstream Tradewind
louaxtjr is offline   Reply With Quote
Old 09-22-2013, 09:59 AM   #2
geezer#99
geezer#99's Avatar
Re: Looking for towing/leveling advice
Here's some info. I had a set on a leaf spring truck. THey're universal and should bolt on your trailing arms. You might need to build some brackets to mount them behind the axle.
http://www.firestoneip.com/riderite/...formation.aspx
Old 09-22-2013, 11:22 AM   #3
louaxtjr
louaxtjr's Avatar
Did you find them to work well unloaded? Any suggestion on application to order for? They do not list for my truck.
Lou Axt, Jr.
Old 09-22-2013, 11:33 AM   #4
geezer#99
geezer#99's Avatar
Didn't even know they where there when aired down. Like I said before you might need to get a universal set and make your own brackets to mount them to the axle.
THere are other options. Helper leafs. Or coil over shocks.
http://www.*********************/for...ead.php?t=3105
Old 09-22-2013, 11:46 AM   #5
louaxtjr
louaxtjr's Avatar
The first link went to the work-rites, which are not aired up or down. Sorry for the confusion. Guess I'll have to call about a universal option. The site seems to list everything by application. Thanks for the suggestions.
Lou Axt, Jr.
Old 09-22-2013, 11:51 AM   #6
geezer#99
geezer#99's Avatar
THe helper leaf might be the best option. THey where a factory option. Could get a spring shop to make some.
I'll find a better link.
Old 09-22-2013, 12:03 PM   #7
geezer#99
geezer#99's Avatar
Here's a pic of a factory helper leaf.
http://67-72chevytrucks.com/vboard/s...helper+springs
And a air bag set up.
Old 09-22-2013, 12:13 PM   #8
louaxtjr
louaxtjr's Avatar
Those helper air bags look like a great solution. I like the adjustability. Just need to find a part number or application to order under.
Lou Axt, Jr.
Old 09-22-2013, 05:11 PM   #9
WIDESIDE72
WIDESIDE72's Avatar
I have run air lift bags inside the factory coils, no brackets required.
WIDESIDE72 is offline   Reply With Quote
Old 09-22-2013, 05:20 PM   #10
WIDESIDE72
WIDESIDE72's Avatar
I believe I have an extra set of the G60 helper springs and brackets. PM me if interested.
Old 09-22-2013, 11:00 PM   #11
I also use Airlift products. The 1000 series is what you need. Feels stock when running minimal pressure,then adds 1,000# true capacity aired up.
http://www.airliftcompany.com/produc...s/air-lift1000
