12-05-2003, 08:19 PM | #1 |
Dash won't light up
I checked every bulb, and they work, took dash out and touched the circut board and there is power to light circut, but still no lights, any ideas,
Thanks guys.
Jock, Powder blasting shop, Alabama |
12-05-2003, 08:29 PM | #2 |
Wiseass secured himself a BAN
Here is what I did when I had that problem. Take the cluster back out and take out each bulb and rub a pencil erasure on each place where the bulb contacts the copper. Reinstall the bulbs. the bulbs complete a circuit. So if one bulb is bad or not gettin power, then the rest will not work. I played with mine for 30+ minutes until they all worked. Worked great for me. the bulbs are very touchy.
12-05-2003, 09:04 PM | #3 |
Inline 69
i had same problem,,,,,,,
it drove me nuts,,,,,there is a "little clip",that has a small black wire, thats a ground,,,,the clip slides over the dash opening(metal edge).the wire "should" be on the right side of the dash opening,,,,,,,,,the clip will look very similar to the one in the pic,,,,,,(your gonna have to take the dash back apart to find it) jeff
12-05-2003, 09:11 PM | #4 |
CCRider
Yep...I vote for the "little clip" I cut mine off and put a real connector on it and fastened it to some metal with a screw
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
12-05-2003, 09:13 PM | #5 |
When I first got my truck, if you turned on the 4 ways, it would blow a fuse that was the tail/brake lights and the instrument lights. Maybe check your fuses?
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
12-05-2003, 09:43 PM | #6 |
Cause the Chicks DIG IT!!
I agree with checking the black wire clip for the ground. That controls your dash lights. If i unplugged mine the dash lights would go out and the high beam warning light would come on.
12-05-2003, 11:14 PM | #7 |
PROJECT 7DEUCE
I had the same problem ..Just ran a ground wire from the cluster to the dash...Good ground = bright lights.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-06-2003, 12:14 AM | #8 |
Responses
Thank you so much for your input, I'll try that tomorrow morning. has been a frustrating day taking several apart and changing things over,
Has anyone ever put after market guages in the guage openings?
12-06-2003, 12:33 AM | #9 |
PROJECT 7DEUCE
Yep but I only had 2 guage's whaen I bought my new bezel and I just had to see what they would look like ... I still only have 2 guage's installed.... Just need to find the time..
12-06-2003, 03:46 AM | #10 |
I had the same issue, found that I had sliced one of the tracers on the PCB board putting the bezel back in to the dash....
12-07-2003, 08:02 PM | #11 |
My 70 GMC had similar problem bit I ended up changing the floor dimmer switch, headlight switch, turn signal switch and regulator. Not a great time finding the problem but I had parts to swap and try and mine needed all I listed.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
