Old 09-22-2013, 06:17 PM   #1
Born Lucky
Wheels
I am looking at the 5 Gen Camaro Wheels and love them. The black steelies.
Can I fit them on a 5x5 bolt pattern?
Born Lucky is offline   Reply With Quote
Old 09-22-2013, 08:47 PM   #2
gixxer711
Re: Wheels
You would have to use thick adapters. New Camaros have a 5x120 bolt pattern.
Danny
64 C10 SWB fleet
gixxer711 is offline   Reply With Quote
Old 09-22-2013, 09:20 PM   #3
Born Lucky
Re: Wheels
Yeah that is what I thought.
And adaptors are not a good idea!
Old 09-23-2013, 04:36 PM   #4
kieth
kieth's Avatar
Re: Wheels
If you already have a 5 x 5 lug pattern with front discs on your truck you can remove the stock studs and have the 5 x 4-3/4 pattern drilled between your 5 x 5 lugs, and they will work. (this is what we did to my truck because of a good deal we got on a set of 17" cragars) just add the proper studs and away you go. The only thing I would check is the amount of back spacingthat those steelies have.....you might need spacers.......Kieth
kieth is offline   Reply With Quote
Old 09-23-2013, 05:07 PM   #5
theastronaut
theastronaut's Avatar
Re: Wheels
You could have the rims reversed to fix the backspacing issue. I've seen it done on a S-10 and they look so much better with a little more lip on the rim sticking out.
theastronaut is offline   Reply With Quote
Old 09-23-2013, 05:10 PM   #6
gixxer711
Re: Wheels
Will need alot of spacer, as new Camaros have real high offsets, like FWD cars. Should be about a 5.75" BS.
Danny
64 C10 SWB fleet
Old 09-23-2013, 05:18 PM   #7
theastronaut
Re: Wheels
How to cut the centers out to change the offset. This guy didn't reverse the wheels, but that could be done if you needed even less backspacing than this.
http://www.s10forum.com/forum/f14/ho...camaro-500744/
Old 09-23-2013, 08:18 PM   #8
joedoh
joedoh's Avatar
Re: Wheels
I'm with theastronaut. I see these take offs on the local craigslist all the time for 4-500 bucks, brand new with tires, and would reverse them just like he said. they look good with the offset changed and would be amazing reversed.
Old 09-23-2013, 08:49 PM   #9
theastronaut
Re: Wheels
It's not difficult to reverse the rims either. I just did a pair of 4" VW smoothies into reversed 5.5" Porsche 911 rims. Just set the backspacing, bolt the wheels up, and check for runout with a dial indicator. Was able to get these down to .045-.055". Then tack the centers in place and have someone who knows what they're doing weld them up.
