#31 | |
Re: Carb school
If your base timing is to high like at 15*btdc and your mechanical is giving 25 because its worn then the combination will give you 40* which while is not bad it's still a tad high esp if your octane is low. Worn hei distributors give a lot of advance sometimes more than 25* in bad cases Try and get 38* by 3500 rpm at least. 10-12* initial is about what stock-even cammed engines like Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
| Bookmarks |
