Help identify this wheel
It's a stock chevy wheel with 5 on 5 bolt pattern with center hole big enough to go over my drum on my 79 c10 but I only have one and want to run them on my 64 if I can find 3 more any help is thankful
[size=1][i]Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
Re: Help identify this wheel
This is another shot of it all the wheels I'm finding where the inner wheel joins the outer ring it's flush in the pic you can clearly see this wheel has maybe 1/2-3/4 inch lip any help is thankful.
![]() Join Date: Mar 2013
Probably came off a 70's chevy or gmc.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
I got a few sets off a late 70's-early 80's G10 Vans. Try Bobby's junkyard off pea ridge. I don't think Babe's would have a set,but you can check. If you can't find any, I might be able to put a set together for you. I can bring them off the mtn next time I come down to Clermont.
#6 | |
#7 | |
Senior Enthusiast
Those also look like the wheels found on 1970's Chevy big cars. They also switched to the 5x5 pattern, along with the big Buicks and Oldsmobiles. There may be a lot of those to pick from in your area, you'd just need to make sure the diameter and offset is what you're after.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
