68 Steering Column strangeness - advice needed
Good morning all. So I picked up this '68 C10 yesterday and found that the PO installed the steering column rotated:
Opening the hood I discovered why, he did it to allow the shift arm to clear the booster: So, questions I have are: Anyone have an idea what MC/booster this is ? (I'm thinking 73-87 truck?) Ideas on how to fix ? I saw the thread in the FAQ on shortening the column, which I think might solve this but opens other cans 'o worms. ![]() |
Re: 68 Steering Column strangeness - advice needed
Yeah, that looks like a much newer booster. The correct booster would look more like this
![]() I don't know how to fix your steering column, other than installing the correct booster Posted via Mobile Device |
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Interesting issue. Wonder what other tricks the PO had up his sleeve?
Inspect your truck fully to ensure there are no hidden safety issues.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
Never seen anyone do that before, an interesting solution, but not a really good idea. The master cylinder looks like one from an 81 or later model, you might be able to put some spacers between it and the firewall.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
From what I remember, it looks a lot like the one on my 2001 Sierra. I could be wrong though, I'd have to go pop the hood and check for sure.
#6 | |
Thanks for the replies all. Yes, the PO had a few more tricks up his sleeve. There is a push button starter switch where the lighter should be.
The truck steers and stops fine, but as you can tell from the pic sometimes the shifter will bind and it's tough to find reverse. @Katrina/10, I'm liking the idea of spacers between the booster and firewall. I assume it would just possibly need a slightly longer rod from the pedal to the booster? |
Why don't you just move the column down enough to clear. The shaft between the end of the column and the steering box is collapsible.
#9 | |
I can't tell from the pic how close your booster is to the firewall, but if it were original (or even the right type of replacement), it would be spaced away from the firewall. Yes that might mean that you would need a longer rod, but check, the PO might have put in an adjustable one.
![]() Join Date: May 2006
Couldnt you just put the correct OEM booster and M/C on your truck, their not that expensive
Or a smaller diameter booster
#12 | |
