Old 09-25-2013, 11:33 PM   #8
Matador
Turn Signals
J Knight's image looks to be exactly what I'm seeing in the column. I'll take a look when the rain stops here. If I lost the return springs, what would that mean? Would it just force me to manually cancel the turn signal lever, or would it mean something worse?
Do I just line the screw up with the lever and attach the two? I can't seem to find the exact part- I'm assuming that just a phillips screw from the hardware store would work? If this is it (I think I saw a hole where the screw should go through the switch to connect the lever), does anyone know the size or length of the screw?
Thanks for the help!
Matador is offline   Reply With Quote
