Old 09-26-2013, 08:14 AM   #1
KCCOS
interior always a tan color???
So my truck is a 62 and is light blue on the outside but tan on the inside. I have noticed that almost all of these trucks no matter what color they are on the outside they are almost always painted that tan color on the inside. Any one have any info on this?
KCCOS is offline   Reply With Quote
Old 09-26-2013, 08:37 AM   #2
1963c-10
1963c-10's Avatar
Re: interior always a tan color???
Fawn was the factory color. You will find some 60-61 is a silverfish color also
1964 Short bed trailer
Old 09-26-2013, 10:25 AM   #3
kieth
kieth's Avatar
IF you want to get official colors exterior and interior go to www.autocolorlibrary.com you will find them there with codes (Ditzler paint) which is now PPG Kieth
kieth is offline   Reply With Quote
Old 09-26-2013, 03:30 PM   #4
concretekiller
i pulled out my carpet last weekend, and sure enough the floor was painted fawn.
concretekiller is offline   Reply With Quote
Old 09-26-2013, 03:41 PM   #5
LT1 Burb
LT1 Burb's Avatar
Some were silver, I have 2 65 cabs, one silver and one fawn.
LT1 Burb is offline   Reply With Quote
Old 09-26-2013, 05:44 PM   #6
oem4me
Is the silver cab Chevy or GMC?
Old 09-26-2013, 06:01 PM   #7
RANDY COX
RANDY COX's Avatar
Mine is Silver 64 model.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 09-26-2013, 07:28 PM   #8
LT1 Burb
LT1 Burb's Avatar
Both chevys,
Old 09-26-2013, 08:06 PM   #9
LVPhotos
LVPhotos's Avatar
All the trucks I have had were fawn. Wiped down the rattle can blue with acetone and found white from the top seam on a-piler to the the rear of seat. Also the dash has wh ite inside gauge area and glovebox. Non deluxe cab.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-26-2013, 09:48 PM   #10
VictoriaHardware
VictoriaHardware's Avatar
Where was the silver one built?
VictoriaHardware is offline   Reply With Quote
Old 09-27-2013, 01:22 AM   #11
spacedebris
My 60 Chevy c30 panel is silver interior, Was made in the Fremont plant.
spacedebris is offline   Reply With Quote
Old 09-27-2013, 01:34 AM   #12
LT1 Burb
LT1 Burb's Avatar
The 65 cab that was silver was the factory air truck I just sold and I believe it was a freemont truck also.
Old 09-27-2013, 02:00 AM   #13
burbluv
burbluv's Avatar
I also have a 62 and am wondering if anyone knows the exact color of the outside of the instrument cluster areas (the off white area)??? Thanks
burbluv is offline   Reply With Quote
Old 09-27-2013, 08:44 AM   #14
1963c-10
1963c-10's Avatar
My 61 silver cab was built in St. Louis. My 63 is fawn and is a Baltimore truck
Old 09-27-2013, 12:39 PM   #15
61K10
61K10's Avatar
Fremont wasn't built in 1960.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-27-2013, 06:16 PM   #16
spacedebris
What was the CA plant in 60 then? I was told it was made in CA and never left. I always assumed it was Fremont.
Old 09-27-2013, 08:08 PM   #17
TJ's Chevy
TJ's Chevy's Avatar
My interior had the fawn tan like color, and one of the rims was the same color. My buck and a 1/2.
Old 09-27-2013, 11:56 PM   #18
JMR5
JMR5's Avatar
Wink Re: interior always a tan color???
It would have been the Oakland plant. Both my 59 and 60 were built there. The plant was located at the corner of 73rd Ave and Foothill Blvd and was in operation from 1917 to 1963 I believe. The location was turned into the Eastmont Mall later and now it's located within the Oakland "killing zone" where there are 100+ homicides a year. My how times change!!
JMR5 is offline   Reply With Quote
Old 09-28-2013, 12:11 AM   #19
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
curious about the silver 65...
I was under the impression that all 60-61 were silver with the charcoal dash, then 62-65 were fawn (tan) with the tan dash, and the 66 was fawn with the brown dash. chev and gmc.
Old 09-28-2013, 07:08 PM   #20
theastronaut
theastronaut's Avatar
Must have been special ordered?
theastronaut is offline   Reply With Quote
Old 09-28-2013, 11:25 PM   #21
likaroc13
Rollin' Old Skool
from everything I've seen & read on here, that's my understanding as well....hmmmm
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 09-29-2013, 02:02 PM   #22
Mack B
Mack B's Avatar
It's totally anecdotal, but when I was a teenager I had a 65 that also had a silver interior, it appeared original and wasn't fawn underneath when it was sanded down.
Mack B is offline   Reply With Quote
