Old 09-29-2013, 03:48 AM   #1
In The Ten Ring
Rust in the gas vent lines.
If (as I expect) my fuel lines are rusty inside, do I need to worry about replacing the gas tank vent lines?
In The Ten Ring is offline   Reply With Quote
Old 09-29-2013, 05:31 AM   #2
cdowns
cdowns's Avatar
Re: Rust in the gas vent lines.
i doubt it
Old 09-29-2013, 08:00 AM   #3
gipper
When I got m truck, it had sat for quite a while. After the carburetor had to be cleaned TWO times, I pulled the tank, flushed it out many times and blue air thru all the gas lines. This was the only way it worked for me.
gipper is offline   Reply With Quote
Old 09-29-2013, 09:51 AM   #4
68gmsee
Active Member
68gmsee's Avatar
That's what ethanol does. If your vent line is rusted check the inside of the fuel tank. Seems like even the new ones will develop a film of rust fairly quick.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 09-29-2013, 11:16 AM   #5
In The Ten Ring
68gmsee,
Way ahead of you man! The tank has been renewed....
Hmm.....that recondense line that goes up into the right rear cab pillar, I'll check with a q-tip but since that allows gasoline to recondense, I might better replace that.
Oh geeze! I'm practically "restoring" my truck!
