09-29-2013, 09:47 AM | #1 |
Gas tank filler neck grommet
Question for the 71-72 Suburban owners.
I am restoring a '72 K10 & see where the rubber grommet that fits around the gas filler neck was never present on mine. I assume they came with one, no ? I bought one from LMC that states goes to the 71-71 trucks & tried to install it but it appears to be too large in diameter to fit. Does anyone know if these Suburban's came with the grommet & if so where I can find one. Thanks guys. |
09-29-2013, 12:17 PM | #2 |
What?
Re: Gas tank filler neck grommet
The only thing burbs have around the fuel filler for a seal, is a thick flat rubber washer that goes between the inner body and the fill tube.
Burbs don't use the thick rubber grommet that the PU's use.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
