Water Pump
Hello, I have a 1968 c10 and I am building a 454 30 over, electric fans, I just purchased the march pulley system, I also bought the long water pump, my uncle is helping me build the engine, but he told me to get the short water pump what is the difference and does it really matter?
#2 | |
Re: Water Pump
69 Chevy 4x4 383 Power ![]() |
Cluster King
![]() Join Date: Nov 2012
Re: Water Pump
Did your March set up come with alt and p/s bracket? That will make a difference in what water pump you need.
Re: Water Pump
when I ordered the pulley system I told them I had the long water pump, are there any pros and cons short vs. long
Cluster King
Re: Water Pump
From a engineers stand point in 1973 when Chevrolet changed from a short style to a long, I have no idea why. The short is good when you have limited space in the engine compartment. The Corvettes actually continued with the short style system well past 1973.
If you already have the set up for a long pump and have the space for it, I would keep it. If you are looking for something that would be period correct for a 1968 pick up then the short style pump and pulleys would be the way to go. The is as far as I know, no difference in cooling efficiency between a long and short as long as the fan / radiator distance is close to the same. |
Re: Water Pump
What amount of distance is optimal??
8/24/13 First Classic Truck '67 ![]() |
