Old 10-01-2013, 11:25 PM   #1
ofnaman
ofnaman's Avatar
Ls swap air intake pictures
I'm working on gathering information and parts for an upcoming ls swap I'm doing on a '80 stepside. I'm having trouble deciding on what I want to do for the air intake. I cannot find a thread on it, if there is one, can you direct me to it? If not, I'm looking for pictures of what you did on your ls swap. Thank you
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 10-02-2013, 12:14 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Ls swap air intake pictures
Pic isn't 100% current, but the intake is still the same. Generic Silverado intake off of Ebay. Cut one side down, flip it over, and use the elbow/coupler in reverse order. Fits good and has room for the MAF without an issue. The same intake can be setup a few different ways depending on which body style and what you need to work around underhood.
[IMG][/IMG]
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-02-2013, 04:38 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Ls swap air intake pictures
Here is a thread that I posted what I did with my TPI setup. Plan to use it on the LSx swap when done also.
http://67-72chevytrucks.com/vboard/s...d.php?t=593464
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-02-2013, 04:41 PM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
http://siliconeintakes.com/
They've got everything you need to piece something together, no matter where you need to run it to.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-02-2013, 08:37 PM   #5
Indian113
Indian113's Avatar
Here's what I did, It's a spectre for a 2004 Tahoe
Indian113 is offline   Reply With Quote
Old 10-02-2013, 09:24 PM   #6
rmvlt1100
rmvlt1100's Avatar
Here is some pics of mine: I got the parts from www.intakehoses.com. and parts from www.hotrodlane.cc. Also called Street and performance. They had the MAF adapter hose and air filter.
Good luck
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 10-11-2013, 09:02 PM   #7
TR65
TR65's Avatar
Here is mine.
Here is a thread on it if you are interested.
http://67-72chevytrucks.com/vboard/s...d.php?t=412824
Good luck. You won't regret the swap.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 10-11-2013, 11:49 PM   #8
jorgensensc
jorgensensc's Avatar
Here is mine.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-12-2013, 12:13 AM   #9
ofnaman
ofnaman's Avatar
Originally Posted by TR65 View Post
Here is mine.
TR
I really like this idea. I saw something similar to this in a car with an ls swap that used a setup like this to go into a functioning cowl hood.
Old 10-12-2013, 06:51 AM   #10
Andy4639
Old member
Andy4639's Avatar
That's pretty slick man I like it.
