Seal questions
At the corner of the hardtop, where the top meets the front part of the body, I have a seal that I don't see in LMC. Are these available anywhere? If not, how necessary are they to a waterfree cab?
![]() Also, I have 2 NOS seals for the top of the door, on the hard top. I know the left side in the picture goes low, and the other side goes high, but in the LMC catalog it looks like that high part should be bigger, and maybe have screw holes? ![]() |
Re: Seal questions
I think you have seals for a single wall top and trying to install on a double wall top, or visa versa. If you have a metal channel around the window opening then you have a single wall top
That large piece you are referring to is part of the door seal. I wouldnt leave anything off, as these things leak bad enough
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-01-2013 at 06:29 PM. |
![]() Join Date: Jan 2001
Re: Seal questions
You also need the rain deflectors, plastic pieces that screw to the windshield frame and the top. They help keep water out of the front corners. Use some RTV black under them to help them seal.
#4 | |
Re: Seal questions
