Old 10-01-2013, 11:39 PM   #1
rs74
rs74's Avatar
Bench seat issue
I recently took the bench out of my old short bed cab and swapped it into my K30. I jumped into it yesterday and when I sat against the back it moved back a couple inches. Not the whole seat just the back part of the seat.So I got back out and pushed on the back and you can push it back a couple of inches before it stops. I checked two of my other seats and they don't do this. When they are back they don't move at all.
When the backs are all the way back the side hinge rest againt a pin I think. So I am starting to wonder if this seat back is sprung or something. I hope all this makes since. If nothing else I will have to try and put up a video of this. I just don't like how it moves back when you set against it. It should be solid when you first set back on it with no movement.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 10-02-2013, 12:51 PM   #2
rs74
rs74's Avatar
Re: Bench seat issue
Tried to upload a video from two different cameras and it wont let me.
So the back part of the seat does not "rest". You can push it back a couple of inches before it bottoms out. Not sure how else to explain it. You can kind of bounce the back of the seat somewhat when you push on it. None of the other three seats that I have do this.
Roy
1987 R10 shortie
Old 10-02-2013, 03:04 PM   #3
79Betty
79Betty's Avatar
Mine in my 77 did this before i pulled it out. The latch on the side where the bolt? Or pin? Stuck out had broken in the seat so it wouldn't latch "tight"
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
