Closed Thread
Old 10-01-2013, 08:28 PM   #8051
mud.man.rj
mud.man.rj's Avatar
Re: What did you do to your truck today!
Wiring can be fun at times.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 10-02-2013, 02:20 PM   #8052
tommys72
tommys72's Avatar
Taped off and painted my new to me wheel covers for my 72
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline
Old 10-02-2013, 03:29 PM   #8053
vidman
vidman's Avatar
Looking good...
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline
Old 10-02-2013, 04:21 PM   #8054
tommys72
tommys72's Avatar
Originally Posted by vidman View Post
Looking good...
I appreciate it... that was alot of tape and time, and they are still 10 footers
tommys72 is offline
Old 10-02-2013, 04:26 PM   #8055
TBONE1964
Cluster King
TBONE1964's Avatar
They look really good Tom. Do you need any of the fake lugs? I have some for you here. Let me know and I will mail them to you.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline
Old 10-02-2013, 08:16 PM   #8056
dibbleg
Got my new Lokar floor shifter installed after having to repair the mess on the floorboards from the PO. Installed new reverse light switch, replaced broken antenna, replaced broken speedo cable, fixed horn button and popped in some turn signal cancel springs. Was actually on sunday, but spent the entire day working on the beast..haha
Chris Mead Tattoos
dibbleg is offline
Old 10-02-2013, 08:45 PM   #8057
Towstrap
Towstrap's Avatar
got her back from paint and all back together and took a glamour shoot
Towstrap is offline
Old 10-02-2013, 08:55 PM   #8058
ksshane
ksshane's Avatar
Installed a new steering wheel and found out that the steering wheel shaft and nut are all but stripped out.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline
Old 10-02-2013, 09:06 PM   #8059
deestrong71
deestrong71's Avatar
Looks Great Tow Strap !
Hope, Faith and Strength
**Deestrong**
deestrong71 is offline
Old 10-02-2013, 09:40 PM   #8060
sboris
sboris's Avatar
Started putting it back together..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline
Old 10-03-2013, 08:18 AM   #8061
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
I got into a minor chingaso and wound up with a broken windshield , I need to find a L.A. Metro area glass shop that'll know how to replace it ~ All Star Glass in GaRDENA TOOK ON THE JOB THEN CALLED ME BACK AND SAID they're too incompetent and cancelled the job .
A little help please .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-03-2013, 09:42 AM   #8062
Lee H
Lee H's Avatar
Nate, I used safelite last year. When I called to make the appointment I told them to verify the tech has experience with 19xx windshield installs and then call me back. They did and made an appointment. With in 20 minutes they left with a nicely installed windshield. They supplied the windshield and I supplied the gasket. Lee
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now
Old 10-03-2013, 11:14 AM   #8063
ole dollor
ole dollor's Avatar
if ya'll remember several months ago ole dollor went through a bad storm and got some paint damage on the hood, top , and left side, well I got it sanded down and am in the process of repainting the hood , top and left side, got some painted yesterday and will do more today, hope it all turns out good. I will try and post some pics later.
ole dollor is offline
Old 10-03-2013, 11:17 AM   #8064
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Ohhhh! I remember.
How about some "before", "during", and "after"? Like while you were doing the first paint.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 10-03-2013, 06:19 PM   #8065
ole dollor
ole dollor's Avatar
Originally Posted by magwakeenercew2jh View Post
Ohhhh! I remember.
a lot of the pic's of the first paint job should be on here, and I posted the damage of the storm. my computer crashed so I will have to look and see if I still have them some where, I will get the new ones some time later, maybe today. I will try and get some of the old and new if that's possible. still need to cut and buff the new paint, so it all will match once I am finished....
Old 10-03-2013, 07:46 PM   #8066
trac209
Made two inch lowering blocks and dropped the rear down. I like the stance now and even the traction seems to have improved
trac209 is offline
Old 10-03-2013, 08:52 PM   #8067
tarafied1
tarafied1's Avatar
I have been disappointed with the power and fuel mileage with my 72 Cheyenne Super. I have only recently bought it. I like all cars/truck but I have been into Fords a long time. I really couldn't understand why this 350 was such a pooch. I know it's about 4,000 lbs. and only a 3.07:1 rear gear but come on! Then I calculated my gas mileage yesterday and it was 7.4 mpg! So I decided something had to be wrong. The PO had converted it to HEI and I put a Holley 600 vacuum secondary on it because the quadrajet was long gone when I bought it. Today I decided to check the timing. First, I noticed that the timing didn't change with the vacuum line unplugged, so I got the vacuum gauge out and had 18 inches at idle. So my vacuum advance does not work. Then I checked initial timing and it was about 7 degrees BTDC. I revved it and it didn't change. I pulled the cap and rotor and saw right away the weights were so sloppy that one was kind of on top of the other so they couldn't move. I jiggled them enough to get them freed up. Put it back together. Set initial timing at 12, winged the throttle and it went off the scale (I don't have a timing light with a dial). So I took it for a drive. WOW it is a new truck! I'm going to get the parts to fix the vacuum advance and bushings for the weights. I am sure the mileage will improve too.
married to TARA, that makes me the TARA-fied1
tarafied1 is offline
Old 10-03-2013, 09:23 PM   #8068
Lee H
Lee H's Avatar
Nice work! Most folks overlook the basics, looks like you nailed it.
Lee H is online now
Old 10-03-2013, 10:26 PM   #8069
tarafied1
tarafied1's Avatar
thanks, I must admit I often over think things too. The truck had been sitting in a field for a while so I was expecting a lot of things to be wrong. So far nothing major.
Old 10-04-2013, 12:26 PM   #8070
Dano69c10
Dano69c10's Avatar
Hey Nate,
I have an extra windshield you can have.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline
Old 10-04-2013, 12:43 PM   #8071
rustytruck50
rustytruck50's Avatar
Got my brake light troubles sorted out....now on to replacing the trailing arms
rustytruck50 is offline
Old 10-04-2013, 02:06 PM   #8072
belldar
belldar's Avatar
Towstrap that is awesome! Love orange!
Heat pressure washed my frame, engine, and tranny yesterday before the snowstorm hit. High pressure steam is a great asset.
1988 1 ton 3+3 custom delux
Coming soon(stroked 496)
TH400, NP205
14 bolt rear, 60 front
4.56 gears, 6 inch lift
35inch dynapro MTs, pro comp 52 16x8 2.5 backspace
belldar is offline
Old 10-04-2013, 03:09 PM   #8073
VWNate1
VWNate1's Avatar
Post Re : Windsheild Fun
Thanx Guys ;
I now have two places to call .
The glass I broke was new Grrr.....
I don't want a used one Dano , thank you all the same ! you've been a real lifesaver .
-Nate
Geezer
VWNate1 is offline
Old 10-04-2013, 04:35 PM   #8074
legotech7
legotech7's Avatar
Fixed the right front parking light, witch wasn't coming on when I pulled the headlight switch, just for the parking light. I had to ground the light housing, and that's all it took. All lights work as they should.....
legotech7 is offline
Old 10-04-2013, 06:19 PM   #8075
ksshane
ksshane's Avatar
Ordered my flip kit
ksshane is offline
Closed Thread
