TH350 problems Shifts at 4500+rpms?
So I drove the truck the other day and it ran terrible. felt like i had to floor it to go what other people were going like 2000rpms. cleaned the oily spark plugs and turned the dist just a hair and it improved like crazy!
then I took it for a test drive and now she wont shift into second gear unless im at 4500+ rpms and even then I have to stomp on it so itll shift. Doesnt really work manually either still the same effect. having to stomp on it to shift gears. hit 3rd gear twice today. Any ideas on what it could be? I figured if it was a vacuum problem it wouldnt shift out of first OH and the fluid is like a dark red and smells smelly. That smelly smell that smells.... smelly. Prolly could use 1/4qt of fluid so ill start there. Havent changed fluid/filter since I got the truck. SM465 swap soon but I would like to drive it/four wheel A LITTLE before I do the swap (christmas time)
Austin 1996 Chevrolet K1500 Silverado ![]() 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
Re: TH350 problems Shifts at 4500+rpms?
Backfires once through the exhaust when cranking.
I believe this has the kick down cable right? Which would be the most like culprit for what you're describing. I don't have the most efficient way of checking/adjusting it but i'm sure google what.
If i'm wrong about the kick down cable the unlikely cause is the governer which i believe can be access from outside the case but is rarely the problem. |
Tranny fluid smells like burnt toast eh!!
And dark red! It's on death's door! Soon to expire. A backfire at start up is retarded timing. Check your timing! |
Have you checked for vacuum leaks? Particularly in the vacuum line that connects to the vacuum modulator on the transmission? Without a way to sense engine load the transmission will not shift correctly, and if the engine has a bad vacuum leak it can neither run correctly nor supply the transmission with an accurate indication of load. If it's been driven alot, or driven hard in a poorly running condition or without the modulator connected the transmission will certainly be damaged, possibly severely.
I know... I know. I just need it to last until decemberish because thats when ill start the swap. I parked it for the day cause it started making me frustrated.
#7 | |
Is your vacuum line to the modulator hooked up? Check the lines
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
78K & 79C Jimmys
yup i'd check that first,top and bottom make sure the hose bit is tight and not oily or cracking
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
It may be stuck. It sounds like its shifting on the govener
yup, if your vac. lines are fine, just replace the modulator. did mine couple yrs ago, was like $15-$18.
my truck pulled this on me last summer, was running up to 3-4 grand before shifting. couldn't find no leaks so i pulled the rubber T fitting off my vac. gauge thinking it mite be plugged, soon as i flexed the T fitting, a huge crack showed up. problem solved |
#12 | |
