09-20-2013, 02:08 PM | #1 |
572 Install Questions
I have searched quite a bit and cant come up with the answers. So I pose my questions to the Forum Guru's:
I am installing a 572 BBC in my '71. I am having a hard time finding a set of headers for it, I am needing at least 2" primary's that will bolt up to a Exhaust port that is D Shaped, all while fitting in my truck. I do have Power Steering, A/C and a TCI 400 Super Street fighter Auto Tranny. I do have a price quote submitted to Kooks for custom headers, but I am hoping there is something that meets my specs out there.
Hope, Faith and Strength
**Deestrong** |
09-20-2013, 02:36 PM | #2 | |
Re: 572 Install Questions
If you want to know what that monster motor will sound like when you are done go here: http://s851.photobucket.com/user/BWF...out-1.mp4.html |
09-20-2013, 03:51 PM | #3 |
All I know is that is awesome love the look. I always wanted to do a 572 swap but out of my budget looks great.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
09-21-2013, 12:45 AM | #4 |
I used Sanderson bb8s on my 402 and have nothing but good things to say about them
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
09-21-2013, 01:47 AM | #5 |
That looks awesome, I just ordered the Sanderson BB8 for my 572 ! Whoop Whoop !
**Deestrong** |
09-21-2013, 03:55 PM | #6 |
Are you using big block stands?
Posted via Mobile Device |
09-21-2013, 04:41 PM | #7 |
havent used anything yet, My Motor hasnt shipped yet.
**Deestrong** |
09-21-2013, 05:03 PM | #8 |
In order to get the most clearance possible, you need to use big block stands and mounts. You have three choices for them.
1. 68-71 non captured type towers/ mounts. The replacement "biscuits" for these are sort of expensive. Some folks have modified small block biscuits. 2. 72 only towers that use a modern captured mount. These are a pittle more expensive initially since they are a one tear only part, but the replacement mounts are cheaper. 3. 73+ frame brackets. These visually look different but are usually cheaper all around. You will have to drill a few holes with these. Posted via Mobile Device |
09-21-2013, 05:49 PM | #9 |
I have Hookers on mine, P/N 2841. They have 2" primaries with a 3.5" collector. I got mine through Summit. Ceramic coated I think they were $769.
They fit pretty good but not without some issues that were easy to fix/fit. The head bolts hit on the flanges, nothing an angle grinder couldn't fix and the driver's side lower control arm "kissed" one of the primary tubes. Again, an angle grinder fixed this also. They hang a little low but I have only "touched" them on a driveway (high center) a couple of times. Last edited by ItsRandy; 09-21-2013 at 05:58 PM. |
09-21-2013, 06:02 PM | #10 |
Another picture.
09-22-2013, 01:08 AM | #11 |
**Deestrong** |
09-22-2013, 01:09 AM | #12 | |
**Deestrong** |
09-22-2013, 04:59 PM | #13 |
Randy, Is that a Ron Davis Radiator?
09-22-2013, 05:09 PM | #14 | |
http://www.ebay.com/itm/Big-Block-Ch...tr#ht_23wt_919 A set of these on my 468 would be much more affordable! |
09-22-2013, 09:46 PM | #15 | |
**Deestrong** |
09-22-2013, 10:26 PM | #16 |
It's an Entropy radiator. http://www.entropyrad.com/ I bought it with 14" fans but after installation it was determined the 14" fans were inadequate. A 16" fan set with shroud was fabricated and Entropy just swapped them, I may have had to pay shipping. |
09-22-2013, 11:21 PM | #17 |
Nice looking headers Randy, I looked at those pretty seriously, but the headers I have know only have 4 inches clearance and decided to try the Sandersons, as they are a mid size header. They wont be below the frame, but unfortunately they only have 1 7/8 Primary tubes. Hopefully that wont hurt my performance too much.
**Deestrong** |
09-25-2013, 05:24 AM | #18 |
My Tranny got here today !
TCI Super Street Fighter
**Deestrong** |
09-26-2013, 08:45 PM | #19 |
Fitz you dont know what kind of Motor Mounts you used in your 572 install do you ?
**Deestrong** |
09-26-2013, 09:47 PM | #20 |
Yes, I do. They were Energy Suspension Part Number: 71907
10-03-2013, 08:30 PM | #21 |
Starting the Upgrade on the Fuel system.
Tank Out, Holley Electric pump mounted, Fuel regulator mounted and fuel lines upgraded to AN lines.
**Deestrong** |
