Old 10-04-2013, 12:08 PM   #1
1968k10blue
1968k10blue's Avatar
cheap engine cleanout
I was wondering, the other day I saw a video of someone pouring water down the carbeurator to clean out carbon deposits, is this safe? I know you can run seafoam through the carb via vacuum line but is water safe to do this with?
Austin
2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked)
2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l
1968k10blue is offline   Reply With Quote
Old 10-04-2013, 12:17 PM   #2
Bryan H
Bryan H's Avatar
Re: cheap engine cleanout
I use to work at a dodge dealership and they would do the same thing with automatic trans fluid. They would hold the throttle 3/4 way down and someone would start pouring. Needless to say it would smoke the whole city block up. Whether it did any good idk.
1980 Malibu Classic 2 dr coupe
1964 Impala SS 4 speed
1968 GMC (major project) grandpa bought new
1969 Chevrolet C-10 Shortbed Fleetside
2008 GMC Canyon (daily driver)
Bryan H is offline   Reply With Quote
Old 10-04-2013, 12:39 PM   #3
DreamRyder1963
DreamRyder1963's Avatar
You can use water but it does not work as well as seafoam. Plus there is not advantage to letting it soak like there is with seafoam.
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 10-04-2013, 12:56 PM   #4
MARKDTN
This works well on my son's go kart. After a while the valves start sticking. Pour in some ATF while it is running gets them lubed up again.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 10-04-2013, 01:00 PM   #5
jcis4me
jcis4me's Avatar
Just a reminder water DOES NOT COMPRESS!!!! You will hydraulic the rod it you add too much. Found out the hard way racing boats and when it flipped over water got in the carb bye bye rod!
Marty
jcis4me is offline   Reply With Quote
Old 10-04-2013, 08:23 PM   #6
mmiddle
mmiddle's Avatar
The water does work, but is DANGEROUS for your motor.
SeaFoam is a way better alternative.
Back in the day engines would carbon up, but now days the gas has so many detergents and ethanol that carbon is not and issue like 20+ years ago.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 10-04-2013, 10:27 PM   #7
TBONE1964
Cluster King
TBONE1964's Avatar
Well what ever you use you need to use in moderation or hydraulicing may be an issue and that does tend to be hard on connecting rods. Good old fashion prestone works very well. Have you ever seen the top of a piston that had a coolant leak on it? It does a great job removing carbon deposits.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 10-05-2013, 01:00 AM   #8
hayhauler71
hayhauler71's Avatar
The reason the piston is so clean in a leaking head gasket situation is the water in the coolant. Water in the combustion chamber produces steam. I have used water for cleaning combustion chambers and it works great but must be done very carefully. There are company's that sell fuel system cleaners that have a special tip [orfice] that is installed in the pcv line that will suck the water or cleaner in at the right rate when the engine is idling
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-05-2013, 07:31 AM   #9
eagleuh1
eagleuh1's Avatar
Seafom works great. I used it on my wifes 2001 Mustang when the V6 would start to knock when hill climbing. Run a bottle through the PCV line while raising the RPM. Smoke the neighborhood and highway all the way into town. But no more knocking from carbon buildup.
eagleuh1 is offline   Reply With Quote
Old 10-05-2013, 07:45 AM   #10
70 shorty
Where's my beer?
70 shorty's Avatar
I remember my buddies dad who was a Chrysler mechanic back in the 60's talking about dribbling water down the carbs on a cross ram 413. He said he rigged up something so it just barely dripped so of course it wouldn't hurt the engine, but instead cleaned it. I"ve used Seafoam myself with noticeable results.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 10-05-2013, 08:59 AM   #11
tlcrz1972
tlcrz1972's Avatar
It does work, I've done both water and ATF, IN MODERATION, don't just dump it down the carb.
Use a spray bottle and just mist it into the intake.
It's an old racers trick back in the 50's -60's, some even made a water injector for going down the track.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
Old 10-05-2013, 01:08 PM   #12
rcrahn
rcrahn's Avatar
If the goal is to remove carbon deposits you want to use something that will both dissolve the deposit and then burn. Water is a poor choice. And as others have said it cannot be compressed, so use too much and it's goodbye rods.
Best to stick with something like seafoam
rcrahn is offline   Reply With Quote
Old 10-05-2013, 01:33 PM   #13
tlcrz1972
tlcrz1972's Avatar
Another way to do the ATF additive is to pour a quart or two into the fuel tank before fill-up.
I've been doing this on my gas burners for years. It's a cheap fuel additive and cleaner.
