A day late and $1 short...
Lube and Additive for 12 Bolt with Eaton Posi
My 8 month old Eaton posi started making noise in turns over the last couple of weeks. I drained the "old" lube and filled it with Mobil 1 75w-90 and a tube of Trans-X posi additive. It still pops... Does anyone have a better option that is available at the local part store?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
Re: Lube and Additive for 12 Bolt with Eaton Posi
GM limited slip additive.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
One of the First
![]() Join Date: Jan 2000
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
x3 on the GM Limited Slip Additive. Whale oil is your 'active ingredient'.
'72 Chevrolet Step Side 350/TH350, '63 C10 Step V8 '74 Trans Am 400, '80 Trans Am Indy Pace Car Mercedes AMG S55, SLK230 Kompressor, GL450 '96 Dodge Indy Ram Official Indy Truck '99 Porsche 911 Carrera |
I couldn't find any "GM" LSA so I put a second bottle of Trans-X in it to see if that will help. If no good than I will ask my dealer to order a couple of bottles and a gasket so I can do another service on it.
Your diff is chattering because the clutches are not slipping when they should. You can order the GM or AC Delco additive from Summit Racing, Jegs, Amazon, Pace Performance or...your local GM dealer.
Yep, I completely understand the why but I was hoping someone had a good experience with a product available at a local auto parts store. I am going to order some of the GM additive as a back up, but I am hoping adding more of the Trans-X additive will get me through Cruising the Coast. I added Trans-X when I installed the all new rear-end at the end of February, which leads me to believe it is inferior. The problem is there is nothing else available locally.
I tried other products also, but nothing worked for me except the GM additive. Most dealerships used to keep it in stock, but I haven't bought any lately.
i always used royal purple in my posi rears and needed no additves the stuff worked great and they were all heavily used himilage trucks not unusal to carry heavy loads to swapmeets and flea markets with 1500mile weekends the norm
I took the truck for a spin between rain showers and it was quiet out back.
