Old 10-07-2013, 10:36 PM   #1
riiano
ignition switch?
Hey, I have a 66 C-10 that I need to replaced the key tumbler in the ignition switch. I do not have the original key. the tumbler in the switch now must be broken because I can turn the switch with out key. I have bought a new key tumbler, but I can not get he old one out. I can not even get the switch out of the bezel. HELP!!
riiano is offline   Reply With Quote
Old 10-07-2013, 11:20 PM   #2
jtrichard
Re: ignition switch?
if you can turn the cylinder then you use a paper clip in the little hole on the side to release the cylinder and remove it ....the bezel wont come off till the cylinder is out
jtrichard is offline   Reply With Quote
Old 10-09-2013, 05:39 AM   #3
luvbowties
luvbowties's Avatar
Thumbs up Re: ignition switch?
jtrichard is correct. Use clip as he said, but while turning ign. switch counterclockwise--toward Lock/Access.
Sam
luvbowties is offline   Reply With Quote
