Old 10-09-2013, 01:59 PM   #1
Andy4639
Old member
Andy4639's Avatar
Cool Re: Best suspension upgrade?
Originally Posted by mike88a View Post
Thanks guys! Been having issues logging in the past few days. My truck has front discs. I am getting ready to do new bushings, ball joints, and such. Trying to decide ride hight ie to lower or not to lower. I appreciate the guidance.
What is the benefit to the rear shock relocating? I thought it came in to play only when lowering?
The rear shock kit that I bought moves the shocks to the outside of the frame. When cornering u can tell a differance. Not near the body roll. I have removed my rear bar since the relocator was going to hit it. I was worried at first but now it's fine without it. Checkout the link.
http://67-72chevytrucks.com/vboard/s...d.php?t=477839
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-09-2013, 02:08 PM   #2
67 chevelle
67 chevelle's Avatar
Lowering your truck will improve handling also ' if you go with the cpp kit ask about their shocks , mine are a few months old and leak , i would not purchace them again , they leak bad
67 chevelle is offline   Reply With Quote
Old 10-09-2013, 03:26 PM   #3
Lees68GMC
Lees68GMC's Avatar
Just opinion from another Old Fart. I'm 6'-2" 275 Lbs.
With my 68 GMC SWB at stock ride height, I always had to pull myself up, using the steering wheel, onto the bench seat. Working under-hood I had to use a step stool and still could barely reach the carb on my V8, while laying over the radiator support, being stabbed in the belly by the hood latch.
NOW after a 2-1/2" front drop and 2 inch rear drop, working under hood is NICE, like working on a Chevelle, standing on the ground I can reach anything under-hood including the firewall. It's also really nice to simply open the door now and slide in, more like a full size car too.
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 10-09-2013, 06:54 PM   #4
Undone
Interesting!
Undone is offline   Reply With Quote
