Old 10-10-2013, 10:09 AM   #1
c10boob
c10boob's Avatar
Unhappy JEGS sight plugs for Holley carburator and my ignorance
When rebuilding my Holley carb I ordered those cool little clear sight plugs for $8 to make float adjustment easier and cleaner.
Yesterday, I took my truck to get it inspected and the guy doing inspections tells me to shut my truck off because it's got a fuel leak and sure enough, there was a giant puddle of gold (or gas) under the truck! This was caused by the fuel melting through the site plug and pouring out...
So apparently those plugs are for adjustment only and not meant to replace the original plugs.. I sure wish the package would have mentioned that for us newbies..
c10boob is offline   Reply With Quote
Old 10-10-2013, 10:12 AM   #2
Longhorn 70
Longhorn 70's Avatar
Re: JEGS sight plugs for Holley carburator and my ignorance
No use crying over spilled gas.
Good news, no fire reported.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 10-10-2013, 10:18 AM   #3
grancuda
grancuda's Avatar
Don't feel bad, you are not the first to run those regularly.
grancuda is offline   Reply With Quote
Old 10-10-2013, 10:40 AM   #4
c10boob
c10boob's Avatar
Yep, lesson learned AND after fixing the leak it passed inspection - so 1 year after buying it I can finally use it as a daily driver!
Old 10-10-2013, 11:24 AM   #5
Keith Seymore
Keith Seymore's Avatar
Huh.
I've had these on my racecar for decades with no issues.
Think the difference is the use of race fuel vs a daily driver with some amount of alcohol/ethanol content in the pump gas?
Or - maybe Holley changed the material that they use to make these?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-10-2013, 12:16 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
K
Notice he said that they are "Jegs"plugs. Nothing against them, just a detail. I too have run clear holley plugs for years.
WIDESIDE72 is offline   Reply With Quote
Old 10-10-2013, 01:40 PM   #7
Keith Seymore
Ah - good point. Noted.
K
1979-1986
1986 - 2019
Old 10-10-2013, 04:32 PM   #8
Wrenchbender Ret
I have never used them but always thought they were installed permantly. It seems if the floats were adjusted correctly there wouldn't be much gas leaking as the fuel level is at the bottom of the opening.
Wrenchbender Ret is offline   Reply With Quote
Old 10-10-2013, 09:13 PM   #9
towbar
towbar's Avatar
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
not if you actually drive the vehicle....fuel sloshes and is everywhere in the bowl.
I have a set of Holley brand in my Malibu, been there for 15 years I suppose. Of course they were made in Bowling Green KY, not Beijing China.
towbar is offline   Reply With Quote
Old 10-10-2013, 09:39 PM   #10
hugger6933
I too have run several sets but then again they were the Holley brand made by the folks here in the good ol USA. Never thought of that being an issue.
hugger6933 is offline   Reply With Quote
Old 10-11-2013, 12:18 AM   #11
oklalawnboy
oklalawnboy's Avatar
Got em on my Demon (basically Holley) carb and no problems here.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 10-11-2013, 07:36 PM   #12
Fitz
The Holley fuel bowl sight windows are a type of high temperature low expansion glass. The JEGS windows are...plastic.
Fitz is offline   Reply With Quote
