Closed Thread
Old 10-11-2013, 10:22 PM   #8126
ksshane
ksshane's Avatar
Re: What did you do to your truck today!
Wired up my electric choke and dialed in my carb.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline
Old 10-11-2013, 10:34 PM   #8127
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Finally got the cover fiasco (sizing issues) cleared up with carscover.com.
Nice folks. And they stood tall.
So, if you need an outdoor/fleece lined cover and can't get it from a Forum Vendor, the "Ultrashield" (100% rainproof - claimed...jury's out until it pours) you want
for a short bed is Product Code 101VLH4AM, regardless of what their make/model matrix wants you to order.
I put it on today. It was bucks-up for me at about $175 shipped. Less than the $500 custom-fit Calcarcover I have had before. But still big dough for me. Fit great
(no mirror pockets - I use oven gloves over the leading edges of the mirrors) Belt-Strap under the center. Elastic front and back. Looks high quality.
Anyone wants a pic or two, speak up.
First and foremost, I go with the supporting Forum Vendors. But I didn't get any response as to rainproof/outdoor guarantees, so I went with that one from www.carscover.com
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 10-11-2013, 10:52 PM   #8128
Tachout
I got the truck up on Jack Stands, pulled the front tires, and orders all my front brake parts. The parts will be in by noon tomorrow so as weather is begining to come in on us, I plan on doing a front brake job. Going to replace everything from rubber hoses out to the drums. I am not replacing drums as they are still in good shape. Looking forward tomorrow.
Tachout is offline
Old 10-11-2013, 10:55 PM   #8129
DWilbur
I cut out Rot in preperation to install new Apillar.
DWilbur is offline
Old 10-11-2013, 11:09 PM   #8130
Patina'd_402
Patina'd_402's Avatar
Fixed a Gauge issue, installed the chrome pulleys that showed up, and stared at the truck.
'70/C10/402/TH400.
Patina'd_402 is offline
Old 10-12-2013, 01:02 AM   #8131
68'CTown
68'CTown's Avatar
I was deciding on whether or not to add a console to my truck and googling pictures thats had custom console but this weekend will be finishing up welding my rocker panels in and patching in some holes that I am filling in.
68'CTown is offline
Old 10-12-2013, 08:22 AM   #8132
sbell87
Oh yea I'm keeping it.. I love it. May even put a 22" steelie on it also.
sbell87 is offline
Old 10-12-2013, 08:46 AM   #8133
slowcpe
slowcpe's Avatar
Starting disassembly mode. The build is officially beginning.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline
Old 10-12-2013, 10:20 AM   #8134
legotech7
legotech7's Avatar
A little pricey. Beautiful truck. Thanks for the measurements...
legotech7 is offline
Old 10-12-2013, 04:11 PM   #8135
dirtyjim
dirtyjim's Avatar
replaced the ball joints and control arm shafts today. still need to do the idler and pitman arms. I also replaced the wore out front springs with a pair from a 90 suburban, I cut one coil from them.
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline
Old 10-12-2013, 08:48 PM   #8136
DWilbur
Got the A pillar test fit today. hope to tack weld it Sunday.
DWilbur is offline
Old 10-12-2013, 09:07 PM   #8137
70 CST 4X4
Have A Nice Day!
70 CST 4X4's Avatar
We cut in the new fuel filler and filled the tank. Worked perfectly
Name:  fuel door 4.jpg
Name:  fuel door 5.jpg
1970 CST K10 350/350/205
Short Bed - Fleetside
Tach-Tilt-A/C-Tow Hooks
Front & Rear Disc Brakes
Front & Rear Posi 3.73 Gears
30 Gallon Stainless Fuel Tank
SOLD 01/18 !!!!!
2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ
70 CST 4X4 is offline
Old 10-12-2013, 11:56 PM   #8138
Valhalla
Valhalla's Avatar
Front brake kits finished
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh
Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own.
SqueegeeMan
Valhalla is offline
Old 10-13-2013, 01:05 AM   #8139
mud.man.rj
mud.man.rj's Avatar
She has bags but with that nice frontend and beautiful rack she is a beauty, sound weird or what Very nice setup, should perform really good too.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 10-13-2013, 07:45 AM   #8140
MACKL
Almost done!
MACKL's Avatar
Washed the girl so I can drive her to church! We both will be better for it.
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline
Old 10-13-2013, 08:52 AM   #8141
88fordf150
88fordf150's Avatar
Nice work!
Brad handshoe
88fordf150 is offline
Old 10-13-2013, 08:56 AM   #8142
elf w/capital T
Correcting rear end, PO had a car rearend, cut springs, blah blah, mocked up my ten inch wide rally and removing rivets to correct shock mounting brackets annndddd shaving the firewall holes where the blower fan Was....
elf w/capital T is offline
Old 10-13-2013, 02:21 PM   #8143
longbed67
longbed67's Avatar
Finally got the opportunity to take the truck to her first show last night and Ended up taking taking best of show! There were so many crowded around the engine bay all night it was a real treat to hear the responses when they realized that I hadn't just dropped a small block under the hood!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline
Old 10-13-2013, 03:04 PM   #8144
Valhalla
Valhalla's Avatar
Lol very good observation
SqueegeeMan
Valhalla is offline
Old 10-13-2013, 03:29 PM   #8145
machinest
machinest's Avatar
Removed my 3speed trans to replace it with one that works .
machinest is offline
Old 10-13-2013, 10:51 PM   #8146
kxmotox247
kxmotox247's Avatar
Fitted sheetmetal all weekend. Wrestled the hood all afternoon mostly due to a mix of OEM and aftermarket parts.
kxmotox247 is offline
Old 10-13-2013, 11:06 PM   #8147
Ridgeclimber
I finally started my winter project. Cut out the cab corner, outer rocker panel, the lower door pillar and the cab kick panel area. Just have to get a couple more patch panel and it will be going back together. Then start the left side. It turned out to be about a six beer job so far.
Ridgeclimber is offline
Old 10-14-2013, 09:25 AM   #8148
legotech7
legotech7's Avatar
Good deal Ridgeclimber, Do us all novices a favor and document how your doing this with pics if possible. I'm sure we can all learn from your experience. I will be doing this soon on mine....
Thanks legotech7.....
Old 10-14-2013, 10:23 AM   #8149
kxmotox247
kxmotox247's Avatar
Yeah! What he said! I'm getting ready to put rockers and a cab corner in too.
Old 10-14-2013, 02:04 PM   #8150
Mike_The_Grad
Mike_The_Grad's Avatar
Please post pics on cab corner and rocker repair.
Mike_The_Grad is offline
Closed Thread
