65 chevy flat bed swap. need ideas
Reaching out to anybody who might own or be doing something similar with a 60-66 Chevy, I am loosing the long box on my 65 c20 SBW to swap for an old wood flat bed, haven't been able to find nearly anything for photo reference. want to see what it might look like when its all done. any advice / pics would be much appreciated.
thanks -matt |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: 65 chevy flat bed swap. need ideas
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Here's mine before I bagged it I plan in putting the bed back on soon.
Sorry not swb
![]() Join Date: Mar 2013
Here's a picture of the ol flatbed that used to be on mine. It's straight on the underneath and the guy used some rail road ties cut to 6 inch wide by 8 inch tall and the length of the frame as the supports. He cut the wood to match the bends of the frame and set the bed on and welded little foot long metal strips and it wasn't going anywere! Took me 4 hours to cut the dang thing off!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Flat beds were also installed by local body companies, one can use channel as the front filler from the frame to the body then have some custom made u-bolts made to tie the front down (some used wood as the filler) at the rear just add a piece of strap 1/4"- 4" x 6-8" bolt it to the frame and weld it to the body long sill. (one can weld behind the rear axle to the frame with out hurting anything) 3" or 4" channel can also be used.......
bit of an update, truck top is painted, bed is off and the doner truck with the flat bed is in the lot. like the old wood and metal, but wondering if i should paint it gloss black, or leave it. any ideas? i'm stuck.
-matt ps: the 1978 chevy c 20 is going up on CL soon. running 350 with 4 speed. |
My '64 flat bed. Bed was a total loss, re used all the attaching points with new hardware and used the stock inner fenders mounted from the bottom up on the wood. Truck is lowered about 4 inches or so, if you have any questions or would like some more detailed pictures let me know. The idea for the very low deck of the wood bed is for the ease of loading bikes.
![]() Last edited by DexterDog; 10-13-2013 at 02:35 PM. |
pretty happy with how it turned out
