Old 10-16-2013, 03:19 PM   #1
AHowe88
Hood Adjustability?
Is there any side to side adjustment in the hood. I can see where you can move it forward or backwards, but that isn't my issue. I think I am going to replace my hood anyways, but I am trying to figure out why my lines are so poor.
Passenger side:
Drivers Side:
AHowe88 is offline   Reply With Quote
Old 10-16-2013, 03:50 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Hood Adjustability?
Holy cow! Is the hood bowed up in the center? I didn't think it was gonna be that bad!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-16-2013, 04:34 PM   #3
Special-Ed
Special-Ed's Avatar
you have some issues... maybe a bad hinge or bent hood
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 10-16-2013, 05:05 PM   #4
tdkosta
tdkosta's Avatar
Mine is doing the same thing. I think my hood hinge is worn out.
tdkosta is offline   Reply With Quote
Old 10-16-2013, 06:17 PM   #5
68 GMC step long
68 GMC step long's Avatar
Looks like a bad hinge on the left side. Can you push the hood down on the left by the cowl to make it go down where it needs to be?
68 GMC step long is offline   Reply With Quote
Old 10-16-2013, 11:36 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Grease the heck out of the hinges and see what happens - when my hoods start sitting up a bit in back this gets them level....good luck
Old 10-17-2013, 08:41 PM   #7
AHowe88
Thanks for all the thoughts, guys. I don't think my hinges are worn out, when I open the hood there is no play. I can't push it into place either. I guess it could be a bowed hood.
Old 10-17-2013, 09:45 PM   #8
GuyO
GuyO's Avatar
Dood, I spent hours and hours trying to get my hood down on the Blazer. Eventually I used a step drill and enlarged the bolt holes to the fender. Finally I got it. Also I used Teflon spray (very expensive) for my hinge lube. It looks passable and works awesome!
GuyO is offline   Reply With Quote
Old 10-17-2013, 11:02 PM   #9
BMERDOC
BMERDOC's Avatar
I drove my truck today. My driver's hinge is junk and the hood ain't all that great. I have to push the driver's side down every time I close the hood. I didn't think about your post until I was almost home. It was dark and rainy. I'll open and close it, without pushing the backside down and compare it to your pic. From what I understand most guys barely loosen the hinges at the fender and push the hood open so that the hinge rocks back and tighten it. That seems to help but yours may be a little excessive.
Nick Carter
Old 10-17-2013, 11:09 PM   #10
jaros44sr
jaros44sr's Avatar
You didnt happen to put a new cowl gasket in it, did you? You wouldnt believe how bad the wrong gaskets can make a hood fit...
Does it make any differance if you put the side rubbers in?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-18-2013, 08:17 AM   #11
Bentblazer
Bentblazer's Avatar
Close the hood slowly and watch the back revets if they move you know what to do, Make sure hinges are good before changing hood
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 10-18-2013, 09:28 AM   #12
D.PASSMORE
One of the First
D.PASSMORE's Avatar
You can adjust hood alot easir with the fender wells removed. That is how I have done mine in the past. Before I installed hinges, I would just sit the hood on front clip on the truck. Check for warpage, look at lines. Take off, install hinges, hood again, bolt down lightly and adjust from inside fender well looking up to hinges mounts. Have rubber hammer, long flat screw driver and a 9/16 short socket and a ratchet set up from flexability. That should determine if its the hood or other body panels out of alignmnet.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 10-21-2013, 04:19 PM   #13
AHowe88
Thanks a lot for the input guys. I need a new hood anyways, so I am looking around for a new one now. There is no play or any movement in the hinge. I'll dig in and report back.
