How many blots hold the engine cradle to the frame?
Holy smokes... how many blots hold the engine cradle to the frame of a 69 truck 2wd? I counted 4 per upper control arm and 3 bolts on each side lower frame. Am I missing something? I thought for sure this would fall right out...
![]() Join Date: Jul 2012
Re: How many blots hold the engine cradle to the frame?
How about two more on each of the engine mounts to cross member
Ha Ha those came off first. It must be rust holding this together. I have two frames and I noticed something cool. One has the engine (hold down/ loop on the LH side of the frame)? riveted to the frame and the other is bolted on the frame.
BlahBlahBlah
Im checking out this thread just so I can find out what the heck a blot is
Florida Edition
![]() ![]() Join Date: Oct 2010
That should be all of them if you are talking about the crossmember. Might want to whack it with a sledge to break it loose. Could be bound up between the frame rails a little.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#6 | |
Florida Edition
The pic isn't the best but you'll get the idea.
Thanks Reno, that's what I thought. This frame has been sitting exposed to the weather so it looks like time for the B.F.H.
