1968 c10 r-n-r front wheel bearings
are there any write ups on the process for replacing the front wheel bearings?
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
![]() Join Date: Dec 2012
Re: 1968 c10 r-n-r front wheel bearings
Loosen front lug nuts slightly
Position jack, raise front wheel Remove Lug nuts and front wheel Remove dust cap from front wheel hub assembly Remove cotter pin and nut cap Remove hub retaining nut and washer. If drum brakes you may need to position the brake adjust slot to the 6 o'clock position and back off the star wheel adjuster Remove outer wheel bearing Replace front wheel nut only. Pull the front drum and hub toward you. The retaining nut, inner wheel bearing and seal should still be on the spindle. Remove hub retaining nut, inner bearing and seal. Clean inspect and repack bearings fully with HD water repellant grease. If replacing bearings install new cones (seats) Some people pack the cavity with grease, I do not. Insert inner bearing. Gently tap in front wheel seal Carefully place hub assembly on spindle install outer bearing, washer and nut Tighten and adjust front wheel bearing to spec. Tap dust cap on Install wheel, lug nuts and lower vehicle Torque lug nuts to spec From memory, I may have left some details out but you get the idea.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
Ha! Thats sweet, yeah its not that hard, just know what bearings you need first, check your wheel studs while your at it...along with brake hardware...
thanks for the great info going to start this project on Wednesday!
