Old 10-18-2013, 11:05 AM   #76
1977cheyenne_C10
1977cheyenne_C10's Avatar
Re: All California Members
but how does it work since i just recently found out that my block is from a 96+ truck do I have to find smog parts from the same year of the block or can i put like a 1977 smog parts?
1977cheyenne_C10 is offline   Reply With Quote
Old 10-18-2013, 11:15 AM   #77
clapage6
it's been said but if you have a 96 block you need to meet the smog requirements of that engine and year. so yes you need 96+ smog equipment
clapage6 is offline   Reply With Quote
Old 10-18-2013, 11:18 AM   #78
1977cheyenne_C10
is there another way how can i find out the exactly year it came from?
Old 10-18-2013, 04:32 PM   #79
InitialBoss
Try to find any info on the block. But I'm not 100% on that.
InitialBoss is offline   Reply With Quote
Old 10-18-2013, 10:53 PM   #80
cool68
Google is your friend. for decoding engine numbers try: http://www.crankshaftcoalition.com/w..._chevy_engines. also for smog info: www.dmv.ca.gov/vr/smog.htm
search California Vehicle Emissions Testing and get a copy of the California Vehicle Code. a professional registration service should be able to help steer you in the right direction. search for one in your area or try Donna Leek for a possible reference to someone in your area: pro.reg.service@gmail.com - I do know of a '76 that has a '92 350 in it that has all of the original smog equipment on it that passes the Smog tests.
cool68 is offline   Reply With Quote
Old 10-19-2013, 03:53 PM   #81
gramps77
Originally Posted by LynnJr View Post
When you take it in if it looks like the original engine you could conceivably get away with anything.
With as TBI engine the smog shop would take 1 look then open the door and look for the aluminum sticker in the door jam.
The aluminum sticker lets the smog shop know what you must smog the truck to in order to be compliant.
My 1972 chevy had a 1974 454 engine in it instead of the 350 so the title says my 1972 is a 1974.
In your case I would have simply went to one of the pull it yourself wreckers and simply got everything you needed including the bolts,brackets and lines.
What are you talking about? They cant simply change the year of your vehicle because of the engine. That make ZERO sense. Most blocks are cost to cover xx-xx years. Such as 68-72 or something similar. So how would they even know which year specifically to turn the truck into? For example, a 330817 SBC 400 has a casting number that shows it was used from 1973-80. So with that simple FACT, are you telling me they would now title your vehicle as an 80? Even more importantly, that splits right down the middle almost, either needing or NOT needing to be smogged. Think about it
Here is the casting number chart I usually use.
http://www.nastyz28.com/sbchevy/sblock.html
gramps77 is offline   Reply With Quote
Old 10-19-2013, 03:55 PM   #82
gramps77
Unless the VIN is stamped on the engine, there is almost no way to tell EXACTLY what year the engine came from. Some may of sat a year or two before actually being fully assembled and installed in a vehicle. What stampings are on your block? If youd like, you can PM me and I'll help you out,
Old 10-19-2013, 06:09 PM   #83
Skunksmash
Skunksmash's Avatar
Originally Posted by mgchevyparts View Post
1975 and older no biannual smog test. If I buy something newer then 1975 it's new.
Man twice a year? That's pretty bad. Once a year is hard enough down here.
Skunksmash is offline   Reply With Quote
Old 10-19-2013, 06:36 PM   #84
KQQL IT
At the body shop.
KQQL IT's Avatar
Once every 2 years.
KQQL IT is online now   Reply With Quote
Old 10-22-2013, 01:13 AM   #85
kylep
kylep's Avatar
my best advice is to find a guy. ask everyone you know. keep asking , see an old truck in a praking lot go up and ask the guy, ask ask and ask somewhere someone wants your money!
2001 Tahoe
1978 K30
kylep is offline   Reply With Quote
